    Anyone up to this??
    11 Posts 3 Posters 896 Views 3 Watching
    • bsintzelB
      bsintzel
      BoltMaker XII (Final) has proven to be very useful. Sadly, it's future is questionable unless someone feels as I, that it warrants some effort. Specifically, the ability to allow one to select from a broader array of nut/bolt configurations. I'd be pleased to assist in beta testing if anyone wants to take this on. 95% of the work is already done. I'll be the first to buy in if it happens.
      From the horses (developers) mouth 😍
      Re: Moving forward with BoltMaker XI???
      Sent: Sat Jun 29, 2013 9:31 am
      To: bsintzel
      No I have no plans for further development of Boltmaker, or any other of my plugins in fact, so it is OK by me if you are anyone else cares to attempt further development to do so.
      I've taken obfuscating to a whole new level!
      • T
        TECHDAVE02
        I have used the bolt maker plug-in a lot
        When I want a different fastener I create it as a component and do a replace selected in the component window. Just be sure that the point of origin is the same the new one.
        good luck
        • bsintzelB
          bsintzel
          Interesting. I'll give it a try 4 sure.
          Thanks 4 the tip πŸ‘
          Here's the bolt configuration I'm trying to reproduce:Furniture Bolt used in folding furniture
          • bsintzelB
            bsintzel
            TECHDAVE02,
            Well I gave your approach a go and got soooooo close. As you can see from the image, matching the replacement component axis to that of the target (MakeBolt component) axis is the issue.
            If I could just identify the axis co-ordinates of the MakeBolt component 'before' performing the 'replace selected' I could 'modify' the axis of the replacement component to match it.
            knowing how to extract the axis co-ordinates of the MakeBolt target is the hurdle e.g., if the components can be viewed as a DC, then I can view the component attributes to get it's x-y-z origin. However, the MakeBolt plugin creates a component that fails to return any component attributes values. πŸ€“
            All suggestion/comments are welcomed
            Bob πŸ€“
            SU8 format
            SU2013 format
            • gillesG
              gilles
              Edit the component to be replaced, go to View/Face style/Xray and you will see the axis origin.
              • T
                TECHDAVE02
                Point of origin issue see below
                try in the file Replace Component-SUv8 TD
                define bolt point of origin (P0)
                PUT A GUIDE IN NEW PART AT THE PO NEEDED
                RIGHT CLICK ON PO IN NEW PART AND PLACE
                PLACE PO TO RELATIVE POINT NEW PART
                SAME POINT OF ORAGIN
                Replace Component-SUv8 TD.skp
                • bsintzelB
                  bsintzel
                  gilles,
                  Thanks for your response.
                  Actually, "seeing" the component's axis isn't my problem -- rather, it's getting the X-Y-Z values relative to the work plane's plane's origin. As you know, component axis are unique in that they exist in there own little 'component' world with their own co-ordinate system relative to the work plane. The relative difference between the drawing plane origin and the components origin is what I'm trying to retrieve in terms of X-Y-Z ordinates. If you've ever played with DC's and the DC attributes window, you'll get see where I'm coming from.
                  Thanks again for taking time to offer your help -- much appreciated
                  • bsintzelB
                    bsintzel
                    TECHDAVE02,
                    Say...now this looks promising. I'll explore it and get back. πŸ‘
                    • T
                      TECHDAVE02
                      Happy Canada Day
                      • bsintzelB
                        bsintzel
                        TECHDAVE02,
                        Damn...that was too easy. 😲
                        No need for attributes now 😍
                        Really appreciate the lesson πŸ‘ . I hope to pay it forward one day.
                        Bob
                        • bsintzelB
                          bsintzel
                          Great Canadian beer, Beaver tails and hockey....man, what a country we live in.
                          Happy Canada Day πŸ’š
