    Anyone up to this??
    11 Posts 3 Posters 864 Views 3 Watching
    • T
      TECHDAVE02
      I have used the bolt maker plug-in a lot
      When I want a different fastener I create it as a component and do a replace selected in the component window. Just be sure that the point of origin is the same the new one.
      good luck
      • bsintzelB
        bsintzel
        Interesting. I'll give it a try 4 sure.
        Thanks 4 the tip πŸ‘
        Here's the bolt configuration I'm trying to reproduce:Furniture Bolt used in folding furniture
        I've taken obfuscating to a whole new level!
        • bsintzelB
          bsintzel
          TECHDAVE02,
          Well I gave your approach a go and got soooooo close. As you can see from the image, matching the replacement component axis to that of the target (MakeBolt component) axis is the issue.
          If I could just identify the axis co-ordinates of the MakeBolt component 'before' performing the 'replace selected' I could 'modify' the axis of the replacement component to match it.
          knowing how to extract the axis co-ordinates of the MakeBolt target is the hurdle e.g., if the components can be viewed as a DC, then I can view the component attributes to get it's x-y-z origin. However, the MakeBolt plugin creates a component that fails to return any component attributes values. πŸ€“
          All suggestion/comments are welcomed
          Bob πŸ€“
          SU8 format
          SU2013 format
          • gillesG
            gilles
            Edit the component to be replaced, go to View/Face style/Xray and you will see the axis origin.
            • T
              TECHDAVE02
              Point of origin issue see below
              try in the file Replace Component-SUv8 TD
              define bolt point of origin (P0)
              PUT A GUIDE IN NEW PART AT THE PO NEEDED
              RIGHT CLICK ON PO IN NEW PART AND PLACE
              PLACE PO TO RELATIVE POINT NEW PART
              SAME POINT OF ORAGIN
              Replace Component-SUv8 TD.skp
              • bsintzelB
                bsintzel
                gilles,
                Thanks for your response.
                Actually, "seeing" the component's axis isn't my problem -- rather, it's getting the X-Y-Z values relative to the work plane's plane's origin. As you know, component axis are unique in that they exist in there own little 'component' world with their own co-ordinate system relative to the work plane. The relative difference between the drawing plane origin and the components origin is what I'm trying to retrieve in terms of X-Y-Z ordinates. If you've ever played with DC's and the DC attributes window, you'll get see where I'm coming from.
                Thanks again for taking time to offer your help -- much appreciated
                • bsintzelB
                  bsintzel
                  TECHDAVE02,
                  Say...now this looks promising. I'll explore it and get back. πŸ‘
                  • T
                    TECHDAVE02
                    Happy Canada Day
                    • bsintzelB
                      bsintzel
                      TECHDAVE02,
                      Damn...that was too easy. 😲
                      No need for attributes now 😍
                      Really appreciate the lesson πŸ‘ . I hope to pay it forward one day.
                      Bob
                      • bsintzelB
                        bsintzel
                        Great Canadian beer, Beaver tails and hockey....man, what a country we live in.
                        Happy Canada Day πŸ’š
