    Scrapbook line weights
    layout
    8 Posts 2 Posters 1.2k Views 2 Watching
      mwm5053
      So how does one make line weights work? I don't find much discusion about them. I see many use for them. Copy/Paste, use the style picker
      LO scrape book.layout
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
        rodman100
        Select the Pencil tool from the main toolbar and sample one of the Line Weights directly from the Scrabbook, no need to drag it into your workspace, the line weight sampled is then applied to the pencil. Any line, rectangle, arc etc. will then have this thickness.
          mwm5053
          Thanks that was easy, but any way to use that to change line weight for model lines from SU
          2011 iMac
          V2 Twilight
            rodman100
            In Layout, go to the Sketchup Model panel and pick the Styles tab, here you can change the style of the active viewport to any of the saved styles. I haven't tried it but it should work. You can create a style in SketchUp to suit your needs (Line Thickness, Colour etc) or download a style.
              rodman100
              Forgot to add a screen pic of the last post...
                mwm5053
                The top line in elevation in SU is the same as rest only edges ticked, no profiles or otheryet it exports in PDF and jpg as heavier line not sure why a graphics thing probably but would like it match rest of model.
                2011 iMac
                V2 Twilight
                  mwm5053
                  I figured it out when I drew the roof I had it setup for a section view to show roof sheeting, paper felt and shingles all adding to the heavier line. Thanks rodman100
                  2011 iMac
                  V2 Twilight
                    rodman100
                    You're welcome!
