    Rounding Corners
    7 Posts 3 Posters 646 Views 3 Watching
      johannpascual
      Hello, SU users!
      I am fairly new to SU. And I'm learning something new everyday and it's great and frustrating.
      Anyway, I'm trying to make this shape (Item 1) have rounded edges. I tried the RoundCorners plugin but it comes out with broken edges (Item 2). Is there another way to make the corners round?
      Thanks a lot, guys!
      After RoundCorner
      • olisheaO Offline
        olishea
        can you upload the skp file? you will get more help. save as sketchup 6 so everyone can open it. πŸ‘
        oli
          johannpascual
          Hello! Thanks for the reply, sir! Here's the file in version 6 as requested.
          File in version 6 format
          • olisheaO Offline
            olishea
            You need to use a neater mesh. The vertices don't coincide and will result in strange behaviour from roundcorner.
            oli
              johannpascual
              Err... how do I do that? πŸ˜„
              Right now, I am using the SoapSkinBubble plugin to make that mesh.
              • ely862meE Offline
                ely862me
                Here's what I would do :
                1- remove the top surface and then clean all the top edges so they match only with the geometry from outside and inside .
                2 - use Curviloft plugin to create a new,cleaner top geometry
                3 - use Tools on surface to create 4-5 contours of the top geometry, then start pushing down the edges/contours to create a round edge .
                4 - If you are looking for a smoother result, you need to remove the extra small segemts that were created from the diagonals
                Lot of work, but it is worth it if your looking for almost perfection.
                Elisei (sketchupper)
                Come and See EliseiDesign
                  johannpascual
                  Wow... that Curviloft plugin is amazing. Thanks! πŸ˜„
