    Placing Model into panoramic photograph
    3 Posts 2 Posters 304 Views 2 Watching
      bailey1
      Hi, newbie here.
      I have a solar farm which I am working on. I have modeled the terrain from contour data and used smart drop to place each individual solar panel module onto the terrain. I have marked 5 viewpoint locations around the model at their correct AOD height. I now want to export the model fro these viewpoints and place it into the panoramic photographs of the existing site. Some of the panoramas are almost 190degrees. My question is how do I export the model to achieve this? I have used position camera and taken a number of scenes and tried stitching them together in photoshop however the exported jpegs dont seem to match. Any ideas?
      thanks
      Alex
      • cottyC Offline
        cotty
        There is a plugin called cubic pano out. You can try to make a spherical panorama out of the cube faces and combine it with your panoramic photographs.
        (Field of view in SU is limited to 120°)
        my SketchUp gallery
          bailey1
          Thanks Cotty
          I tried that, seems to work ok.
