    Adding a cost structure to Dynamic Components
    1 Posts 1 Posters 841 Views 1 Watching
    • D
      DaveM65
      Hi Guys
      I know this is a bit of a strange question, but I will outline what I want to do...
      Basically, I design exhibition stands in sketch up, using components, these are usually a system based set of components that are used to construct the main frame work of the stand, what I wanted to know was if there is a way of allocating a single cost to each of the components and being able to bring up a total cost for all components used in the design. I don’t want to have to count each of the items every time as its time consuming.
      I understand you can add a cost for a material, but that does not quite do what I would like it to do.
      I look forward to your replies
      Dave
