    Shortcut question
    4 Posts 2 Posters 451 Views 2 Watching
    • genma saotomeG
      genma saotome
      Prior to SU 8 I had a functioning shortcut for texture/position. It disappeared when I changed over to SU 8 and I've not been able to re-create it.
      IMO the default menu for doing anything with applied textures is perhaps the worst aspect of an otherwise fine user interface and I'm dismayed at the prospect of being stuck with it again.
      Did google remove something or have I just forgotten how to set it up again? If the later, would somebody remind me of what to do?
      • gillesG
        gilles
        First select a face (no edge) and you will find it in Preferences/shortcuts.
        • gillesG
          gilles
          http://support.google.com/sketchup/bin/answer.py?hl=en&answer=114922&topic=2458785&ctx=topic
          "Select the command to which you will assign a keyboard shortcut (within the Function list). Existing keyboard shortcuts for this command will display in the Assigned list.
          Note: The list of commands available in the Shortcuts panel is dynamically generated and includes all menu items and active context menu items. Some context menu items become active only after performing another task. For example, select a face to activate the Reverse Faces command and then open Preferences > Shortcuts to set a keyboard shortcut for Reverse Faces."
          • genma saotomeG
            genma saotome
            That's the trick!
            THANK YOU very much!
