    Newbie reporting in! ...and in need of some help with solid
    3 Posts 2 Posters 366 Views 2 Watching
    • S
      SKYWAYS128
      Hello all!
      It's been about a week since I started using Sketchup, and it's far easier to use than I expected.
      Anyways, I have a question regarding soap skin bubble and solid inspector. I used soap skin bubble to cover a curved part of an object, and it works fine. But when I used solid inspector to check for "leaks", it lit up the "skin" made by soap skin bubble even though the area is completely covered.
      Is this just a false alarm on solid inspector's part?
      Thanks in advance!
      • gillesG
        gilles
        Soap Skin creates a group, did you explode it to merge with your object?
        • S
          SKYWAYS128
          Thanks, Gilles!
          That did the trick.
