    Game running half the speed in SU 2013 vs SU 8
    27 Posts 6 Posters 2.2k Views 6 Watching
      Anton_S
      Your amazing Chris πŸ‘
      Adding model.start_operation('KeyScene', true) when the user clicks the start button and calling model.commit_operation when user clicks the reset button seems to increase performance dramatically!
      I take all my thoughts back, and do say that Trimble SU2013 is an extreme progression!!!
      Thank you SketchUp Team!
      Thank you Trimble!
      Thank you Chris!
      • renderizaR Offline
        renderiza
        @dacastror said:
        How is configured by default "Sketchup 2013"?
        Here is how it looks on SketchUp 2013 Make
        But! If I change that default setting that option is gone and the only way I can get back to it is if I reinstall again which is little weird.
        @chris fullmer said:
        Here are the results from 3 rounds of tests:
        Thanks for does tests its really good to know 2013 is faster giving your results. I am still confused as to way in my game the SketchUp 2013 version runs very slow compared to SketchUp 8.
        Sounds like you made KeyScene work much faster...but was it faster than version 8?
        Also I am not sure how can I add model.start_operation in Resballiza game to see if it will make it faster. Can you help me in that regards?
        I am so thankful to all of you great job so far!
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
          Anton_S
          Yes, it's a little faster on SU2013 than on SU8
          I sent you a PM with a fixed copy of both KeyScene and Resballiza πŸ‘
            driven
            @Chris,
            can you test on mac as well?
            my results don't look so great.
            EDIT: reformatted to make it clearer...
            run on both versions with Sketchup.plugins_disabled? => true then false
            simple cube, grouped:
            %(#0000FF)[v2013 mac plugins turned off
            Transform Slow = 4.051424
            Transform Fast = 0.689763
            Invert Transformation = 0.682962
            Combined Slow = 4.149032
            Combined Fast = 0.685753
            nil
            true
            v2013 mac plugins turned on
            Transform Slow = 4.684443
            Transform Fast = 1.141925
            Invert Transformation = 0.87607
            Combined Slow = 4.773361
            Combined Fast = 1.152288
            nil
            false]
            %(#8000BF)[v8 mac
            Transform Slow = 2.187031
            Transform Fast = 0.795604
            Invert Transformation = 0.809627
            Combined Slow = 2.293091
            Combined Fast = 0.784819
            nil
            true
            v8 mac
            Transform Slow = 2.299228
            Transform Fast = 0.805798
            Invert Transformation = 0.985101
            Combined Slow = 2.456473
            Combined Fast = 0.818888
            nil
            false]
            john
              renderiza
              Magnificent! 😍
              Now Resballiza is way faster than before in SketchUp 2013!
              SketchUp 8 runs little bit faster still but not by much...I will study ways of optimazing code to make it faster but as is right now it is playable. πŸ’š
              Again thanks Anton_S and Chris Fullmer for all the help! πŸ‘
              • Chris FullmerC Offline
                Awesome, glad its improved! Thanks for working that into his code Anton, great!
                @John - I have not yet tried it on Mac. I'll see if I get a chance here soon.
                All my Plugins I've written
                  Anton_S
                  @renderiza said:
                  SketchUp 8 runs little bit faster still but not by much...I will study ways of optimizing code to make it faster but as is right now it is playable.
                  Sounds great, I will be the tester πŸ˜„
                  It was interesting, I never actually knew that setting the second parameter of model.start_operation to true would actually improve the performance. That is an important parameter to know, especially when your dealing with geometry plugins.
                  • 2 / 2
