    ACAD Export Errors
    3 Posts 2 Posters 2.8k Views 2 Watching
    • S
      seasdes
      I have had the following error message when trying to export a 2D graphic to DWG from SU8 and 2013:
      "AutoCAD export audit error:
      Check\Audit report.txt\ for errors."
      Does anyone know where this report may be found and what may cause it.
      Using Sketchup Pro 2019
      • R
        rv1974
        purge your skp file with the same name script. If it won't help try to export area by area
        (with some geometry optionally hidden by layer)
        • S
          seasdes
          Thank you a purge fixed it.
