    Scene manager plugin?
    6 Posts 3 Posters 677 Views 3 Watching
    • onzkiO
      onzki
      Is there a fast technique or a plugin to activate "use sun for shading" for all the scenes? I already saved 60 scenes but I was so forgetful that I failed to tick the "use sun for shading option". Something like a scene manager plugin that can quickly change:
      1. sun shading option (my priority right now)
      (in the future I might also tweak the following):
      1. shadows
      2. Rename scenes
      Thanks! πŸ˜„
      [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
      • KrisidiousK
        Krisidious
        go to the scene manager window and then use the shift key to select multiple scene tabs and edit their properties.
        I know it's counter intuitive, but if you turn off save shadow settings, then go to one scene and turn on shadows, I believe all the scenes will then have shadows.
        By: Kristoff Rand
        • renderizaR
          renderiza
          You might want to have a look at [Re]Scene ... http://sketchucation.com/forums/viewtopic.php?f=323&t=52203
          Cheers!
          [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
          • onzkiO
            onzki
            Ok I'll try this. thanks!
            • onzkiO
              onzki
              @renderiza said:
              Cheers!
              Looks amazing, thanks!
              • renderizaR
                renderiza
                I noticed that your #3 request was renaming scenes and although I have seen this being requested couple of times I have not integrated that feature to [Re]Scene so maybe I should get working on that.
                In the mean time you can do this;
                Steps to learn how to rename all scenes with little code.
                Step1. Download "Ruby Code Editor" by Alexander Schreyer
                link: http://extensions.sketchup.com/en/content/ruby-code-editor
                Step2 Copy & Paste the code I provided below.
                Step3 Done! (Play with code to modify it)
                model = Sketchup.active_model ;
                pages = model.pages ;
                @page_name = "Name" ;
                @page_num = 1 ;
                pages.each do |page|
                    page.name = "#{@page_name}#{@page_num}"
                    @page_num = @page_num + 1
                end ;#Pages.each
                I'll be working on integrating this feature soon to [Re]Scene...Cheers!
