    Holes in fills
    layout
    9 Posts 5 Posters 2.3k Views 5 Watching
      ArCAD-UK
      In LO is it possible to create a filled shape with a hole in it? I can't find any indicators that it can be done. I want to create a filled rectangle with a hole in it that will display the information through the hole. Think along the lines of a rectangular wall with a cut out to show a window.
      • KrisidiousK Offline
        Krisidious
        white out areas can be made by drawing a closed loop and then turning off the stroke button in shape style and turning on the fill button with a color of pure white. this closed loop can draw the object you seek.
        here's an example, I made it grey so you could see it.
        white out window
        whiteoutwindow
        By: Kristoff Rand
          ArCAD-UK
          Thanks Kris, that is the workaround I came up with after posting. I was hoping there was an add or subtract function I had missed. Looks like I need to add it to the wish list for SU 2013 pro M1 release πŸ˜‰
            Krisidious
            well, if you're inserting a model you can always constrict the viewport to the view you want. just make sure that the rescale window check is not check-marked in the sketchup model window. but this only works in squares and rectangles.
            By: Kristoff Rand
            • RichardR Offline
              Richard
              You can do the same but use the slice tool to get rid of the closing line, if you are wanting stroke.
              BUILTBRAND.COM.AU
                Aarhus8000
                Is it possible to punch a hole in the white area in Krisidious's example to reveal the SketchUp model behind it? That is: Create two shapes, merge them and delete a "face" like you would in SketchUp?
                • RichardR Offline
                  Richard
                  Nope! You could drop the SU model over the top of a filled rectangle of larger size! Or add a stroke to the SU model frame! You can make the stroke thicker by typing in a value!
                  BUILTBRAND.COM.AU
                  • pbacotP Offline
                    Is this something like you are looking for? A clipping mask with the model, then put the gray rectangle behind (model has filled background).
                    And it works with any shape.
                      Aarhus8000
                      Yeah, that could solve the problem. Thanks guys!
