    Component Axis Display Option
    9 Posts 3 Posters 377 Views 3 Watching
    • K Offline
      ktkoh
      I tried this code from the API in an attempt to find the Option name for controlling the component axis visibility but it does not run. There is a optionsmanager but the options.name line fails.
       model = Sketchup.active_model
       optionsmanager = model.options
       if (optionsmanager)
         # If an options manager is returned, iterate through each option
         # provider within the options manager and display its name.
         for option in optionsmanager
           name = options.name
           UI.messagebox name
       else
         UI.messagebox "Failure"
      Is there a code method for controlling the component axis visibility?
      Keith
      • Dan RathbunD Offline
        Dan Rathbun
        It is not in the options manager / provider hierarchy.
        It is in the model or scene page rendering_options hierarchy.
        object.rendering_options["DisplaySketchAxes"]= false
        The object can be a Sketchup::Model or a Sketchup::Page instance.
        πŸ’­
        I'm not here much anymore.
          Dan Rathbun
          OR...
          object.rendering_options["DisplayInstanceAxes"]= false
          • K Offline
            ktkoh
            Dan that code controls the global axis. I am trying to control the individual component axis visibility.
            Keith
              Sketchup.active_model.rendering_options['DisplayInstanceAxes'] = true
                Instead of using messageboxes to inspect the possible options I use these snippets:
                Sketchup.active_model.rendering_options.each { |k,v| puts "#{k} - #{v}" }
                Sketchup.active_model.options.each { |op| puts op.name; op.each { |k,v| puts "> #{k} - #{v}" } }
                • K Offline
                  ktkoh
                  Thanks that's what I needed. I am always amazed at how quick I get answers on this forum. I would never be able to find these on my own.
                  Wouldn't it be nice if the examples in the Sketchup Documentation actually worked.
                  Keith
                    +1
                      Dan Rathbun
                      And if you had read the NEXT post after THAT, before posting you would have seen I gave you the instance key as well.
                      Lesson: Read the whole thread before posting.
