    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 164.1k Views 79 Watching
      Jorgensen
      Hi Pascal
      I have just purchased the plugin (version 1.10.07) and installed it in SU 8 pro.
      I get an error when I try edit a tree πŸ˜•
      Do you know how I can avoid this?
      [EDIT]
      It seems to work if I just press ok.
      Is it somehow possible to speedup the redraw process - I'll have to wait several minutes before the tree is updated πŸ˜•
      I guess it's a limitation of Sketchup, but I find the plugin hard to use then I have to wait this long every time πŸ˜•
      sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
      • OxerO Offline
        Oxer
        I came back to the v1.06.04 because this version draws the trees in few seconds (between 3 and 8 seconds in my computer), but there is one inconvenient, you lose the feature make grass and other features related with the Materials, present in the last version.
        [http://www.oxervision.blogspot.com/(http://www.oxervision.blogspot.com/)]
        • ppoublanP Offline
          ppoublan
          Hi Jorgensen,
          Did you try with the last version : 1.10.11 that is published in the Plugin store here or from this link :
          http://www.3darcstudio.com/downloads/3darcstudiotree/3darcstudio_tree_v1.10.11.rbz
          Download the file,
          Setup using standard SU rbz extension install
          After install, exit and restart SU
          Did the error still occur ?
          If yes let me know and we will try other tests. First time I see it, so I need more investigation.
          Does anybody here also got the same error ?
          Regarding speed:
          • on 2 different PCs I'm using, drawing a tree is less than 30s for the more complex one and less than 5seconds for the standard generic tree.
          • be sure you close the Sketchup Outliner window: this is the main cause of slowness I have seen as SU try to refresh outliner for all geometry changes within scripts
          • ensure also that additional plugins that checks for geometry changes (like render viewport) are not running while you are drawing a tree as they will try to update
          • the script also runs a little bit faster on SU 2014.
          Yours
          Pascal
          • ppoublanP Offline
            ppoublan
            Dear all,
            another tip to use tree maker with better performance, to place trees within large models:
            • I build/change configuration of the tree in an new empty Sketchup model
            • When I'm happy with the result, I convert it to proxy with the integrated tree maker proxy function
            • Then I copy/paste this component (which is small) to the final model where I can make instances
            • When all trees are in place and I want to render, i use "redraw all" in the final model, this can take some time if many trees, but have to do it only once before rendering
            • I also use the proxies features of the renders when available (Thea, Octane, ...)
              Yours
              Pascal
            • ppoublanP Offline
              ppoublan
              Hi Oxer,
              The main difference is that the old version is making SU groups, not components.
              Using components is really more efficient when you need to place many instances, and you got also a SU file that is lighter.
              So yes time to draw with the new version is a little bit more slow to draw one tree (on PC), but a lot much faster to redraw 20 or more trees as only the component is rebuild, not all instances.
              This was the reason I make this change to integrate features like grass.
              But as I really have acceptable performance on PC/2014 (few seconds to draw most of the trees), maybe i have a specific issue of speed with Mac.
              I will try to add few time logs to the next version so see what is slowing down the most.
              Yours
              Pascal
              • OxerO Offline
                Oxer
                I found a plugin that it makes slow down the drawing of trees, BGSketchup_Composants.rb, with this plugin installed the drawing of tree02:Cypress takes 47 seconds, without the plugin installed the drawing takes 12 seconds, other example, the drawing of tree00:Default Generic Tree takes 6 seconds without plugin, with the plugin installed 55 seconds.
                Mac OSX 10.9.4 & SU2014 with Tree Maker v1.10.11
                  Jorgensen
                  I tried to removed all plugins, and the script seems to run ok - but I still get the error.
                  If I install octane render, the problem happens again (things take very long time), even with the Octane Viewport closed.
                  So it seems that octane render somehow sesses things up in my Sketchup.
                  • ppoublanP Offline
                    ppoublan
                    Dear all,
                    Just fixed the issue with script error when loading configuration webdialog.
                    New file published in PluginStore and on my website.
                    Version is 3darcstudio_tree_v1.10.11a.rbz
                    Yours
                    Pascal
                    PS : do not understand why javascript is executed differently when called from SU8 and from SU2014, but...
                    • ppoublanP Offline
                      ppoublan
                      Hi Oxer,
                      Great to know. Thanks for tests you made.
                      My understanding is that other plugins may add entities observers to Sketchup to be informed of any entity change. I'm not sure if this is the case for those you mentioned but I will have a look. When this is the case, each time a change is made to an entity, the third plugin is called. As drawing a tree make lots of change to entities within tree component, it add time due to all these calls.
                      Yours
                      • ppoublanP Offline
                        ppoublan
                        Fixed (SU8).
                        I'm also using Octane and cant see important additional delay to draw tree when viewport closed, Could you make a test with SU2014 as Octane Plugin is different for SU2014 ?
                        Yours
                        Pascal
                          Jorgensen
                          Hi pascal
                          Not sure I understand you right, but I don't have sketchup 2014.
                          Maybe I should reinstall sketchup and octane.
                          • ppoublanP Offline
                            ppoublan
                            You can download SU2014 for free and setup it + Octane Plugin just to see if it change the performance on your environment.
                            • N Offline
                              noicrilo
                              this plugin is really awesome, thanks of sharing your work.
                              I notice on mac OS and sketchup 2014 that the tree bar (with the 4 icons) is always reloaded when program opens,
                              it is very annoying, can you fix this bug? I’m working with all other features and it seems all fantastic and useful πŸ˜„
                                albertoricordi
                                QUESTION:
                                How can I include my own trees in the drop-down menu library?
                                • ppoublanP Offline
                                  ppoublan
                                  @albertoricordi said:
                                  QUESTION:
                                  Right click on a tree, then "Save as template..."
                                  choose a different file name that the one proposed if you do not want to overwrite existing template. You can also create the preview image (that is displayed when this tree will be selected in the new list)
                                  Yours
                                  Pascal
                                  • ppoublanP Offline
                                    ppoublan
                                    @noicrilo said:
                                    I'm not sure to understand, or maybe its not working the same way on Mac.
                                    On PC, View>Toolbars> uncheck 3DArcStudio Tree Maker. Does this menu exists on mac ?
                                      menes
                                      @alan fraser said:
                                      Brilliant plugin, Pascal...and very configurable...both during and post production. πŸ‘ πŸ‘ πŸ‘
                                      The tree on the left is a default Olive...but with simplified leaf geometry (down to 3 faces per leaf). It is now down to only 21,000 faces.
                                      The tree on the right is another default Olive, but with even simpler leaves (1 face) but double the number of leaves; and minus all the small twigs. This is down to only 12,000 faces. It was only 7000 before I doubled the leaf count (by simply selecting the foliage group, duplicating and rotating it.)
                                      Hi Alan,
                                      Great your Olive tree,
                                      I'm struggling much, because of too much slowness of the Pc, to obtain a similar one. Too much to ask if you could give me directions on the values ​​that you used?
                                      obtain a so Olive tree with only 12000 faces really could help much.
                                      thanks in any case
                                      • ppoublanP Offline
                                        ppoublan
                                        thanks in any case
                                        Here are few tips to improve performance and reduce size of trees with this plugin :
                                        Tips to reduce tree size :
                                        • Reduce the number of faces and segments of the tree. It may change a little bit the way the tree looks like, but generaly you will be able to keep the same global look without loosing much quality. Only 3 or even 2 faces are often enough for small branches (branches level 2 or 3).
                                        • Use leaves with lower number of faces (as the β€œsquare” face for example, one quad face = 2 triangle faces only with 4 vertices) and apply png texture
                                        • You can create you own leaves/flowers with lower number of faces. To do this, draw a tree, open window components, add a leaf from the component list, edit it and change it. (show the hidden geometry if you want to see all the edges of the leaf faces). Hide/soften the edges. This is not mandatory but it gives a better look. Hide also outer loop edges. Save it with a new filename in the subdirectory β€œleaves” of the tree plugin. You can now use it within your trees
                                        Tips to improve performance issues
                                        • Disable shadows, fog, profiles of edge styles and complex styles
                                        • Close the outliner window (do not ask me why, but its true!)
                                        • Disable plugins that add component or entities observers (they will add additional time at every tree draw). It s for example the case for the Eneroth railroad. (do not remove the plugin, I’m a big fan of it, just turn it off when drawing the trees)
                                        • Use the proxies features :
                                        • Turn all trees to proxies before saving your model, you will drastically reduce the Sketchup file size.
                                        • Work with trees in proxy mode when you are working on other parts of your model
                                        • Turn all trees to full draw only when you need to render or capture your final image
                                        Hope this helps.
                                        Yours
                                        Pascal
                                        • I Offline
                                          ijmccoy
                                          superb plugin, is there a guide for it at all?
                                          also with the model im working on at the moment whenever i try to render the leaves disapear and ive no idea why, any help would be great
                                          Ian
                                          • ppoublanP Offline
                                            ppoublan
                                            Not yet, but I'm working on it... will publish it as soon as available.
                                            Which render do you use ?
                                            i've made tests with Octane, Thea, Kerkytea. I could try with your render with evaluation version.
                                            I know some issues with the renders I tested but with good results.
                                            yours
                                            Pascal
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 12 / 17
