    Global Hash in module (solution without $ ) ?
    5 Posts 3 Posters 487 Views 3 Watching
    • jolranJ
      jolran
      Hi.
      During some googeling(think it was St.overflow) I found this solution for making an hash that has constant scope
      in module. Which permits to pass the hash through classes in a module without the use of globals$.
      It's appears to work pretty fine, but I then wonder if it is an acceptable method for working with Sketchup?
      I.e doesent polute the plugin directory or can create havoc for other plugins.
      (it would be unfortunate to trust a solution and then find out it's a big NoNo, later on..)
      Maybe some of you guys have similar stuff implemented already..
      Here's a snippet variant of what I'm using.
      module My_stuff
      module DOSTUFF
      #initialize Constants..
      class Container
          attr_accessor ;objstorage
          def initialize
              @objstorage = {}
      OBJECTLIST = Container.new #new Hash with global scope in module.
      # Add something to Hash..
      OBJECTLIST.objstorage[;key] = "Somevalue"
      # Additional code goes here......
      class Myclass
          def initialize()
              @something = OBJECTLIST.objstorage[;key]
         #Add stuff....
      end #class
      end #DOSTUFF
      end #My_stuff
      • A
        Aerilius
        I don't see the difference yet from
        OBJECTLIST = {}
        Can you elaborate?
        • jolranJ
          jolran
          Hah, neither do I πŸ˜„
          Your solution is better, I knew some of you foxes had a simpler solution.
          Can't remember what the fuzz was bout creating a whole class for a Hash..
          Maybe for some mixin purposes ? (which I do not need)
          In any case I'd stick to your method.
          • TIGT
            Or something like ?
            ###Usage;### AAA;;XXX.new()
            module AAA
            @@h={}
            @@h['xxx']='zzz'
            	class XXX
            		include AAA
            		@@h['yyy']='aaa'
            		def initialize()
            			@@h['zzz']='ccc'
            			@@h.sort.each{|h|puts "#{h[0]}=#{h[1]}"}
            • jolranJ
              jolran
              Thanks TIG.
              Your variant is probably more than I need for the moment, but still very clever.
              And I presume (since nobody mentioned it already) quite safe to use ?
