    Dynamic Components Bug
    2 Posts 2 Posters 697 Views 2 Watching
      Aetria
      Hello all!
      I´ve been constructing a catalog of furnitures for the place I work, and the dynamic components have presented a weird bug.
      When I insert one component from the 3D Warehouse, change one of its atributes, and then add another dynamic component, if I try to change its atributes, it doesn´t work for the whole component.
      Don´t know why this happens, or if it´s a previously mentioned bug (if it is, I´m sorry for creating another post for it, didn´t find it on previous posts).
      Thanks 😄
      In the image, I´ve added the left component first, changed it´s atribute.
      If I try to change the second added component atribute, this happens. When you check the atributes configuration, it shows that the function changed its path, following the first component.
      • P Offline
        pcmoor
        Hi, I am currently building some dynamic components, "pcmoor", for building construction. I too have been frustrated, however I believe the problem is in editing independent of the main model. For example before reusing a previous component to build the next, copy within a main model, then make all parts unique, use the outliner to select all the sub components at once, then make unique. thus any changes will not effect similar components. Then if you want too place into another file. One day someone needs to write a book....interested?
        cheers
        Philip
