Walls vanishing
Hello to all
I've had this problem twice already using Sketchup for Windows8. I was half way done with a drawing and suddenly as i zoomed in, instead of going through walls or glass,at a certain point it behaved like i hit a invisible wall and the drawing would start to disintegrate.
Is this a matter of the file being to big?....i had a large amount of components.
Any help what can be causing this?
Thank you -
Hi Hector and welcome!
This is called "clipping" and a good wealth of things can cause it. Review this "list" and check your model if any of the reasons (or fixes) may apply http://support.google.com/sketchup/bin/answer.py?hl=en&answer=36261
Register LoginAdvertisement
