    Plug in for LenX, LenY, LenZ
    7 Posts 3 Posters 865 Views 3 Watching
    • K
      KrisM
      I have looked but can't find what I'm looking for. I work with timber frame and need the axes to be correctly oriented so that when I run "Generate report", the information is not garbled. It would be convenient to click on an object and have the LenX, LenY, LenZ displayed as a quick check that the the axes are correct. Anyone have any thoughts?
      Regards,
      Kris
      • BoxB
        I'm not totally sure about your question but,
        You can set the line colour to show axis in the styles settings.
        • K
          KrisM
          Good point for the axes check. I would also like to have the dimensions displayed so I know the material size is correct and know the length.
          Kris
          • BoxB
            Entity info window?
              Kris, re: dimensions, check your PMs.
              • K
                KrisM
                Box,
                Unfortunately, the Entity Info window doesn't show what I want. Only a single length, area or volume. It doesn't give dimensions for a whole object. It would be nice if it did.
                Dave has pointed me at a plugin that seems to do the job.
                Kris
                • BoxB
                  No probs, I'm just giving you the basics, Dave has the good stuff.
