    How to store slected file directory name on a variable?
    6 Posts 3 Posters 502 Views 3 Watching
    • renderizaR Offline
      renderiza
      Hi, I want to have the user open a directory folder (expample C:\Users\name\Desktop\GOSUFiles)...then pick a file (example: sound.wav) and click ok.
      After user click ok the directory address of that file will be stored in a variable like this...
      @sound = C:\Users\name\Desktop\GOSUFiles\sound.wav
      How can I do this?
      Thanks in advance!!!
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • Dan RathbunD Offline
        Dan Rathbun
        Easy ..
        def get_sound_file(title = "Choose a sound file")
          filepath = UI.openpanel( title, "*.wav" )
          if filepath
            @sound = filepath.gsub("\\",'/')
          else
            return nil
        end # method
        On Windows the browser will open to the last path where the user selected a ".wav" file.
        Windows keeps track of MRU (Most Recently Used) paths for all file extensions.
        If you want to put the user in a specific directory, then:
        UI.openpanel( title, absolute_path, "*.wav" )
        If you do not want to filter by extension...
        UI.openpanel( title, absolute_path )
        The UI file browse methods are bugged and we cannot specify multiple file extensions.
        πŸ’­
        I'm not here much anymore.
          renderiza
          :: Dan Rathbun ::
          Thank you so much this was exactly what I wanted!
          I have another question... 😳
          Lets say I only want to choose folder and not a file...how can this be done?
          Again thanks!
            renderiza
            I kinda found a way, here it is...
            def get_folder(title = "Choose a folder")
              filepath = UI.openpanel( title, "" )
              if filepath
                file_path = filepath.gsub("\\",'/')
                @folder = File.dirname(file_path)
              else
                return nil
            end # method
            Only draw back is that you need to pick file in other to get folder anyway...but its ok I guess.
            Cheers!
              Since / as path separator isn't hard coded I tend to use:
              @sound = File.expand_path(filepath)
              One could also do:
              @sound = filepath.gsub("\\", File::SEPARATOR)
              But I prefer the first.
                Dan Rathbun
                @Rafael: The API UI module does not have a folderpicker, YET. We have filed Feature Requests for one, and fontpicker, and colorpicker, and etc., etc.
                For now users must pick a file within the target folder. (We are out of luck if the folder is empty.)
                One could also do:
                Your second one is safer. Yes I got lazy, but my purpose here is going from the OS to Ruby. I imagine that after tha statement the path will be used by Ruby's Dir and File methods.
                Later on... to go back to the OS I'd use filepath.gsub("\/", File::SEPARATOR) if it is even necessary.
                Be careful with expand_path() because it is DUMB!
                Your example will work only because the UI.openpanel method returns an absolute path.
                When the path is a relative path,... the method simply concatenates the current working directory path and the argument path, regardless if the result is really a valid path.
