    Extract camera position
    11 Posts 4 Posters 631 Views 4 Watching
    • greenskpG Offline
      greenskp
      Hey guys.
      what requirements to i extract position x,y,z of the camera and put them in a blank sentence?
      For example:
      camera:
      vx, vy, vz
      and my sentence is:
      ("camera location = (" + l2str(vx) + ", " + l2str(vy) + ", " + l2str(vz) + ")")
      • renderizaR Offline
        renderiza
        Try this...
        @@model = Sketchup.active_model ;
        peye = @@model.active_view.camera.eye ;
        UI.messagebox("Camera location = #{peye}") ;
        Cheers!
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        • greenskpG Offline
          greenskp
          nice code!
          and how i put these values to enter into vx, vy and vz?
          • Dan RathbunD Offline
            Dan Rathbun
            Also Ref: [ Code ] save Camera properties method
            Also on PC ONLY there is a built-in Camera properties dialog.
            require('sketchup.rb')
            unless RUBY_PLATFORM =~ /(darwin)/i # not for Mac !
              tag = "Camera Properties;#{File.basename(__FILE__)}"
              unless file_loaded?(tag)
                UI.menu('Camera').add_separator
                UI.menu('Camera').add_item('Camera Properties...'){
                  Sketchup.send_action(10624) # MS Windows ONLY
                file_loaded(tag)
            đź’­
            I'm not here much anymore.
              Dan Rathbun
              @greenskp said:
              nice code!
              cam = Sketchup.active_model.active_view.camera vx,vy,vz = cam.eye.to_a
              and ...
              puts("Camera location = #{cam.eye.to_s}") %(#000000)[>>] %(#008000)[Camera location = (0", 0", 1")]
              (when units are Inches... but if units are mm, then output is:
              %(#000000)[>>] %(#008000)[Camera location = (0mm, 0mm, 25.4mm)]
              đź’­
                renderiza
                I think you mean like this...
                vx = peye.x
                vy = peye.y
                vz = peye.z
                vx = peye.x
                vy = peye.y
                vz = peye.z
                UI.messagebox("Camera location = #{vx}, #{vy}, #{vz}") ;
                Cheers!
                • greenskpG Offline
                  greenskp
                  Thanks Renderiza but the code returns me this result: (~ 1,91, ~ 1,63, ~ 0,06)
                  It can return results like this? (1.91, 1.63, 0.06)
                  One more thing. Whit this code i can get camera target position?
                  It´s possible that to each Scene created i have different coordinates?
                  > vx = peye.x
                  > vy = peye.y
                  > vz = peye.z
                  Cheers!
                  Thanks for answer Dan Rathbun. I will test your code tomorrow.
                    renderiza
                    You can remove the "~" symbol by doing this...
                    vx = peye.x.to_feet
                    vy = peye.y.to_feet
                    vz = peye.z.to_feet
                    or
                    vx = peye.x.to_mm
                    vy = peye.y.to_mm
                    vz = peye.z.to_mm
                    BUT! problem is that the number of decimals added might be a lot. I will like to know if there is a way to reduce the number of decimals to only two places.
                    cheers!
                      renderiza
                      Here is the SOLUTION!
                      vx = peye.x.to_feet
                      vy = peye.y.to_feet
                      vz = peye.z.to_feet
                      dp=2
                      vxa = (vx*10**dp).round*10**-dp
                      vya = (vy*10**dp).round*10**-dp
                      vza = (vz*10**dp).round*10**-dp
                      UI.messagebox("Camera location = #{vxa}, #{vya}, #{vza}") ;
                      Note:
                      The user TIG posted the solution in this site...https://groups.google.com/forum/?fromgroups=#!topic/sketchupruby/623a05vZfys
                      So thanks TIG!
                        vx = peye.x.to_feet
                        vy = peye.y.to_feet
                        vz = peye.z.to_feet
                        or
                        vx = peye.x.to_mm
                        vy = peye.y.to_mm
                        vz = peye.z.to_mm
                        cheers!
                        The ~ is because the X, Y and Z values are of the Length class, which when converted to string will use of the model settings for representing units. This is normally what users expect to see so I'd encourage to not change that.
                        More info on units in SketchUp: http://www.thomthom.net/thoughts/2012/08/dealing-with-units-in-sketchup/
                          renderiza
                          Dan Rathbun posted a ref link that have things like target, direction, ect
                          example
                          ptarget = @@model.active_view.camera.target ;
                          Not sure what you mean by this. If you click remember camera position in scene manager then yes you will change camera placement with scene.
                          Cheers!
                          Note: Thanks thomthom for explaining why that happened!
