    How to select last entity selected?
    6 Posts 3 Posters 459 Views 3 Watching
    • renderizaR
      renderiza
      When I select multiple entities how can I use the last selected to use on code or maybe the first one.
      These are not doing it for me;
      @@sel = Sketchup.active_model.selection[0] ;
      or
      @@sel = Sketchup.active_model.selection.first ;
      Thanks and if I reply to myself again don't think I am crazy! XD
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • thomthomT
        Not sure if the model.selection collection relates in any way to the order entities where selected.
        You might want to use a SelectionObserver...
        • thomthomT
          Btw, model.selection.first won't work - you'd have to convert it to an array first: model.selection.to_a.first
          • Dan RathbunD
            Dan Rathbun
            Gotcha Thom...
            The API defines a first() instance method for Sketchup::Selection
            so:
            Sketchup.active_model.selection.respond_to?(:first) %(#008000)[> true]
            πŸ˜›
            I'm not here much anymore.
            • thomthomT
              Ah! Oh the joy of API inconsistency! I actually tested selection.last - and just assumed...
              • renderizaR
                renderiza
                I have tried but seems I can't get it to work or understand correctly. Is there a sample code that can better illustrate this.
                Thanks!
