    How to recognize cursor on top of texture?
    6 Posts 2 Posters 492 Views 2 Watching
    • renderizaR
      renderiza
      Hi, I am about to finish my next update for Canvas plugin but I am having trouble with cursor on top of texture. Here is link to Canvas... http://sketchucation.com/forums/viewtopic.php?f=323&t=51655
      So Far I have this done;
      Add:: On Vertex
      Add:: On Edge
      Add:: On Face
      Add:: Group
      Add:: Component
      Add:: On Image
      But I still trying to finish these;
      Add:: On Texture - Can't solve it at the momment 😞
      Add:: On Shadow - (I made a thread asking this and I am close to finishing it...just need little more time)
      Add:: On Selection - (Have not tried yet so don't know if I will have problems)
      I tried this;
      def onMouseMove(flags,x,y,view)
      ip1 = view.inputpoint x,y ;
      point = ip1.position ;
      select_comp=view.pick_helper
      select_comp.do_pick x,y
      selected_comp=select_comp.best_picked
       if flags == 1 && @@sel != nil && @@texture_addon == true && selected_comp.is_a (Sketchup;;Texture) == true
         add_object(point) ;
      end #def
      Thanks in Advance!
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • renderizaR
        renderiza
        Here is a WIP
        I managed to recognize the material by doing this;
        selected_face=select_comp.picked_face
        selected_face_mat=selected_face.material
        # Add On Texture
        if flags == 1 && @@sel != nil && @@texture_addon == true && selected_face_mat != nil
        	add_object(point) ;
        Now I need see how I can integrate texture material in there....wish me luck!
        • renderizaR
          renderiza
          I feel weird replying to my own posts but I solved it!
          Just need to add .texture at the en of selected_face_mat like this...selected_face_mat.texture
          # Add On Texture
          if flags == 1 && @@sel != nil && @@texture_addon == true && selected_face_mat.texture != nil
             add_object(point) ;
          Cheers!
          • thomthomT
            That won't work if the face have the default material - in which case selected_face.material will return nil - and you can't call nil.texture
            Also - no need to do: selected_face_mat.texture != nil
            nil evaluates to false and any other value evaluates to true.
            • renderizaR
              renderiza
              For the Canvas Plugins now have this two Add:: On Features;
              Add:: On Material - I am actually happy that the default material returns nil because it may pass as a mask feature πŸ‘
              Add:: On Texture - This one is working as it should at the momment adding groups or Coponents on top of entities with textures only and ignores any kind of entities with material color only & no texture image.
              Cheers!
              • thomthomT
                But this line will cause an error:
                If selected_face_mat is nil then you cannot call .texture on it.
