    Parisian Fence material: 3 sizes available in 2 colours.
    4 Posts 3 Posters 2.3k Views 3 Watching
    • simon le bonS
      simon le bon
      "Un grand bonjour" to you all my good friends of SketchUcations forums I haven't been in contact for long.
      This thread:
      "Simple (low-poly) lattice component by cotty"
      http://sketchucation.com/forums/viewtopic.php?f=40&t=51167
      and the so kind intervention of Gaieus and Pilou
      Which was referring to this one:
      An exercise: DRAWING A PARISIAN FENCE
      http://sketchucation.com/forums/viewtopic.php?f=15&t=29342
      had given me the idea to achieve the following materials (Su + Thea + Photoshop)
      Small + medium + tall Parisian fences png with transparent alpha serie available in white an green
      @broomstick said:
      that image would make a great map with an opacity mask on it 😉
      @gaieus said:
      True, I was also thinking about it. You can easily make it tilable horizontally, too - the only problem is that vertically it should be a bit higher so that you could apply it on more various (although of course, still limited) height.
      So here they are:
      The gift ;-)
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thminiParisianFence2Green_small.png;original
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thminiParisianFence5White_small.png;original
      DOWNLOAD SECTION:
      White and green series in low resolution available for anyone:
      https://mega.co.nz/#!KEsWlRyb!Ho7nYQryDNJVVje-vIFSgB_ZfeFI2SSpIqLCE68gFcg
      https://www.dropbox.com/s/2mho9b15megge0q/ParisianFencesWhite%26GreenMat_lowResolution.zip
      (Re: TAFF GOCH MODEL available in 3D Warehouse:
      Parisian Fence - "Beefier" Version)
      http://sketchup.google.com/3dwarehouse/details?mid=1f9d9c90922e59ca2137e32e8ebf2b1
      And a preference for SketchUcation member's
      White and green series in high resolution + photoshop files containing Diffuse,alpha & normal + the skp SU6 model
      Oups! ->wrong text file: rectified 😳
      ParisianFenceMat#downldLinks_2.txt
      With my sympathy,
      ++Simon
        Grillage de Provence 😉
        • GaieusG
          Excellent stuff, thank you a lot, Simon! 😄
          • simon le bonS
            simon le bon
            @Pilou,@Gaieus 👍 😄
            Oups! ->wrong download text file: rectified in first post 😳
            nice "trouvaille" Pilou
            (Remembering)
            @taffgoch said:
            Simon,
            Consider how the manufacturer produced the fence. Q: With what did they start?
            A: A length of "wire," with a constant, repeated sine wave. This should be maintained in a 3D model. Keep all of the sinusoidal segments the same length.
            Truly, the sine segments along the top of the fence will be curved, but they should be maintained at the same length. I can demonstrate this evening, when I have some modeling time.
            -Taff
            http://sketchucation.com/forums/viewtopic.php?f=15&t=29342#p256185
            Grillages de Provence 1
            Grillages de Provence 2
            *s
