    Kerky bump issue
    extensions
    7 Posts 4 Posters 1.1k Views 4 Watching
    • pbacotP Offline
      This is a bump pattern in Kerkythea but probably this sort of thing relates to other programs...
      In the picture the bump of the horizontal joints seem right but not the vertical ones. On the same wall at other lamps it all looks fine (further away). If I invert it I would get it all looking wrong. It as if the light is coming from the wrong direction, yet joints are still recessed.Screen Shot 2013-04-01 at 7.22.30 PM.pngScreen Shot 2013-04-01 at 7.25.11 PM.png
      Any ideas? Thanks, Peter
      • olisheaO Offline
        olishea
        is your face reversed?
        oli
        • pbacotP Offline
          Nope. (but would I ever admit it here, if it were?!)
          • tridemT Offline
            tridem
            though, your map seems wrong since reliefs should correspond to white areas. Note that the material preview has a bug and works on the contrary way
            • olisheaO Offline
              olishea
              πŸ˜†
              oli
              • pbacotP Offline
                I was curious if I had run up to a common mistake. I want to find a better bump anyway so I'll see if once i get, or make a new texture, I'll find the right results. Thanks for the replies.
                • N Offline
                  notareal
                  I believe tridem is right. You need to invert colors of the bump map.
