    Sketchup send action for paste..
    6 Posts 4 Posters 1.9k Views 4 Watching
    • BurkhardB
      Burkhard
      ...I can get.
      Is there an equivalent to paste in place? I can find nothing.
      http://www.ia-plus.de
      • A
        Aerilius
        Sketchup.send_action("paste:") (only in the Windows version of SketchUp)
        • BurkhardB
          Burkhard
          Sorry Aerelius, I have the "paste" code but could not find "paste in place".
          (My english 😳 )
          • TIGT
            There is no 'paste_in_place' send_action [there's probably an unsuppoorted numerical PC-only code somewhere??] 😞
            If you want to 'move' something from one context into another then you must first have it as a group/instance, then add an instance of it into the new context, respecting the relative transformations...
            If it's initially loose geometry and in the active_context then something like:
            gp=model.active_entities.add_group(model.selection.to_a)
            will work to make it a group, BUT if not SketchUp will Bugsplat !
            Let's assume we have a group referenced as 'gp'... to put a 'copy' of it into another 'context' use:
            gp2=another.entities.add_instance(gp.entities.parent, tr)
            Where 'tr' is the transformation of the 'another' container relative to the original...
            If you have two instances of the same group using gp2.make_unique will avoid issues if you change one but don't want to change the other...
            If you want to 'move' it between contexts [aka cut+paste_in_place] then after you create the new instance use gp.erase! to remove the original.
            If the selected object is a component instance ['ins'] then it's slightly different...
            ins2=another.entities.add_instance(ins.definition, tr)
            Again use ins.erase! if it's a 'move 'rather than a 'copy'...
            The transformation of a group/instance is got from tr=gp.transformation or tr=ins.transformation, to find the 'inverse' use tr.inverse! etc depending on the 'direction' of the transformation you are applying... Multiple transformations can be accumulative - using tr2*tr1*tr0 from inside...out.
            • dukejazzD
              dukejazz
              I found this awhile back
              send_action code
              21939 Insert clipboard contents at original location.
              http://sketchucation.com/forums/viewtopic.php?f=180&t=23321&start=0
              thus this is a 'paste_in_place'; a send_action code for -pc only (7,1 - 8.m5 ...)
              Sketchup.send_action(21939)
              For the Mac I would like to know too?.
              • TIGT
                BUT since there is no ability to change the active-context through the API then paste-in-place is pointless...
                If you Cut or Copy then Paste with send_action it's sine because the original selected object and the newly copied/cut then-pasted one are in the same context, and the user gets the copy on their cursor to place manually.
                But let's assume there were a seemingly usable Paste_In_Place send_action available through the API, how would it be of any use ?
                Say you are in the the model and want to Cut an object, open a Group and then do a Paste_In_Place on the object inside the Group.
                In the API you can Cut it.
                BUT you are now stuck as you can't open the Groups context.
                Paste_In_Paste will simple place the object back where it was, in the current context !!!
                There IS a way to replicate all of this 'in code'... BUT your Ruby_Cut and Ruby_Paste_In_Place into another 'container' custom code needs to make a group of the selected objects, then find that group's definition and then use container.entities.add_instance(defn, trans) on the other container's entities context, applying the container's transformation onto it [with a .inverse ? I write this 'off-the-cuff'], so that it's kept 'in_place'. Once that is done you explode that newly added group inside the container, then finally you erase the original group so the selection appears to have been cut and pasted_in_place into the other container... If you mimic a Ruby_Copy and Ruby_Paste_In_Place it's similar... except on completion you also explode the original group rather than erasing it, and in that way the selection appears to have been copied and pasted_in_place into the other container...
