    Hide/Show Objects
    8 Posts 5 Posters 488 Views 5 Watching
    • Z Offline
      Zacchia
      Sometimes when hide objects with contex menue they are not shown anymore when say "show all" again, they seams to be lost... Just sometimes. Anyone seen this also??
      • BurkhardB Offline
        Burkhard
        Maybe you had hide these in Groups or Components. You have to do the same steps as when hiding.
        http://www.ia-plus.de
        • BoxB Offline
          If you hide something while you are in a group or component for editing then you need to be in that group/component again to unhide it.
          Turn on hidden geometry in the view menu and you will see hidden bits as ghost grids.
          • gillesG Offline
            gilles
            If you don't kwon where you lost one, open Window/Outliner an develop the hierarchy, works better if you have named them.
            • BoxB Offline
              That's true gilles, but if it is ungrouped geometry it still wont show in outliner.
              For example, while a hidden group will show as hidden in outliner, a single hidden face won't.
              • gillesG Offline
                gilles
                Your right, this is why we have groups and components and use them.
                • Jean LemireJ Offline
                  Jean Lemire
                  Hi folks.
                  If loose geometry is not in a group or a component but is on a hidden layer, Edit Menu --> Unhide --> All will not reveal this geometry. The layer must be made visible.
                  Just ideas.
                  • Z Offline
                    Zacchia
                    Thanks for answers!
                    I did not know the thing about hide inside a group/component... I understand now! Thanks!
