    Ruby script of bezier curves need edit
    5 Posts 3 Posters 2.0k Views 3 Watching
    • piratebrianP Offline
      piratebrian
      I operate a CNC machine and use SketchUp-Pro as the primary CAD for the machine. I want the bezier curve ruby script to make curves with more than 20 segments. The CNC machine will cut the curve in a smooth contour so long as the segment length is quite small but with this script draws always with 20 segments.
      I have tried to edit the ruby script, changing all references to the number 10 or the number 20 to a higher number re-saved and ran it, with no effect.
      What needs changed in the original ruby script to make this happen?
      I appreciate assistance in this matter.
      Below is the raw ruby script code as downloaded from http://www.sketchup.com/download/rubyscripts.html: (under the heading bezier.rb)
      <span class="syntaxdefault"></span><span class="syntaxcomment">#&nbsp;Copyright&nbsp;2004-2005,&nbsp;@Last&nbsp;Software,&nbsp;Inc.<br /><br />#&nbsp;This&nbsp;software&nbsp;is&nbsp;provided&nbsp;as&nbsp;an&nbsp;example&nbsp;of&nbsp;using&nbsp;the&nbsp;Ruby&nbsp;interface<br />#&nbsp;to&nbsp;SketchUp.<br /><br />#&nbsp;Permission&nbsp;to&nbsp;use,&nbsp;copy,&nbsp;modify,&nbsp;and&nbsp;distribute&nbsp;this&nbsp;software&nbsp;for&nbsp;<br />#&nbsp;any&nbsp;purpose&nbsp;and&nbsp;without&nbsp;fee&nbsp;is&nbsp;hereby&nbsp;granted,&nbsp;provided&nbsp;that&nbsp;the&nbsp;above<br />#&nbsp;copyright&nbsp;notice&nbsp;appear&nbsp;in&nbsp;all&nbsp;copies.<br /><br />#&nbsp;THIS&nbsp;SOFTWARE&nbsp;IS&nbsp;PROVIDED&nbsp;"AS&nbsp;IS"&nbsp;AND&nbsp;WITHOUT&nbsp;ANY&nbsp;EXPRESS&nbsp;OR<br />#&nbsp;IMPLIED&nbsp;WARRANTIES,&nbsp;INCLUDING,&nbsp;WITHOUT&nbsp;LIMITATION,&nbsp;THE&nbsp;IMPLIED<br />#&nbsp;WARRANTIES&nbsp;OF&nbsp;MERCHANTABILITY&nbsp;AND&nbsp;FITNESS&nbsp;FOR&nbsp;A&nbsp;PARTICULAR&nbsp;PURPOSE.<br />#-----------------------------------------------------------------------------<br />#&nbsp;Name&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;&nbsp;&nbsp;Bezier&nbsp;Curve&nbsp;Tool&nbsp;1.0<br />#&nbsp;Description&nbsp;;&nbsp;&nbsp;&nbsp;A&nbsp;tool&nbsp;to&nbsp;create&nbsp;Bezier&nbsp;curves.<br />#&nbsp;Menu&nbsp;Item&nbsp;&nbsp;&nbsp;;&nbsp;&nbsp;&nbsp;Draw->Bezier&nbsp;Curves<br />#&nbsp;Context&nbsp;Menu;&nbsp;&nbsp;&nbsp;Edit&nbsp;Bezier&nbsp;Curve<br />#&nbsp;Usage&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;&nbsp;&nbsp;Select&nbsp;4&nbsp;points-<br />#&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;&nbsp;&nbsp;1.&nbsp;Start&nbsp;point&nbsp;of&nbsp;the&nbsp;curve<br />#&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;&nbsp;&nbsp;2.&nbsp;Endpoint&nbsp;of&nbsp;the&nbsp;curve<br />#&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;&nbsp;&nbsp;3.&nbsp;Second&nbsp;control&nbsp;point.&nbsp;&nbsp;It&nbsp;determines&nbsp;the&nbsp;tangency&nbsp;at&nbsp;the&nbsp;start<br />#&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;&nbsp;&nbsp;4.&nbsp;Next&nbsp;to&nbsp;last&nbsp;control&nbsp;point.&nbsp;&nbsp;It&nbsp;determines&nbsp;the&nbsp;tangency&nbsp;at&nbsp;the&nbsp;end<br />#&nbsp;Date&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;&nbsp;&nbsp;8/26/2004<br />#&nbsp;Type&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;&nbsp;&nbsp;Tool<br />#-----------------------------------------------------------------------------<br /><br />#&nbsp;Ruby&nbsp;implementation&nbsp;of&nbsp;Bezier&nbsp;curves<br /></span><span class="syntaxkeyword">require&nbsp;</span><span class="syntaxstring">'sketchup.rb'<br /><br /></span><span class="syntaxdefault">module&nbsp;Bezier<br /><br /></span><span class="syntaxcomment">#&nbsp;Evaluate&nbsp;a&nbsp;Bezier&nbsp;curve&nbsp;at&nbsp;a&nbsp;parameter.<br />#&nbsp;The&nbsp;curve&nbsp;is&nbsp;defined&nbsp;by&nbsp;an&nbsp;array&nbsp;of&nbsp;its&nbsp;control&nbsp;points.<br />#&nbsp;The&nbsp;parameter&nbsp;ranges&nbsp;from&nbsp;0&nbsp;to&nbsp;1<br />#&nbsp;This&nbsp;is&nbsp;based&nbsp;on&nbsp;the&nbsp;technique&nbsp;described&nbsp;in&nbsp;"CAGD&nbsp;&nbsp;A&nbsp;Practical&nbsp;Guide,&nbsp;4th&nbsp;Editoin"<br />#&nbsp;by&nbsp;Gerald&nbsp;Farin.&nbsp;page&nbsp;60<br /><br /></span><span class="syntaxdefault">def&nbsp;Bezier</span><span class="syntaxkeyword">.eval(</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">t</span><span class="syntaxkeyword">)<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">degree&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length&nbsp;</span><span class="syntaxkeyword">-&nbsp;</span><span class="syntaxdefault">1<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">degree&nbsp;</span><span class="syntaxkeyword"><&nbsp;</span><span class="syntaxdefault">1<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">return&nbsp;</span><span class="syntaxdefault">nil<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;t1&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">1.0&nbsp;</span><span class="syntaxkeyword">-&nbsp;</span><span class="syntaxdefault">t<br />&nbsp;&nbsp;&nbsp;&nbsp;fact&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">1.0<br />&nbsp;&nbsp;&nbsp;&nbsp;n_choose_i&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">1<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;x&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">x&nbsp;</span><span class="syntaxkeyword">*&nbsp;</span><span class="syntaxdefault">t1<br />&nbsp;&nbsp;&nbsp;&nbsp;y&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">y&nbsp;</span><span class="syntaxkeyword">*&nbsp;</span><span class="syntaxdefault">t1<br />&nbsp;&nbsp;&nbsp;&nbsp;z&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">z&nbsp;</span><span class="syntaxkeyword">*&nbsp;</span><span class="syntaxdefault">t1<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">for&nbsp;</span><span class="syntaxdefault">i&nbsp;in&nbsp;1.</span><span class="syntaxkeyword">..</span><span class="syntaxdefault">degree<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;fact&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">fact</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">t<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;n_choose_i&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">n_choose_i</span><span class="syntaxkeyword">*(</span><span class="syntaxdefault">degree</span><span class="syntaxkeyword">-</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">)/</span><span class="syntaxdefault">i<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;fn&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">fact&nbsp;</span><span class="syntaxkeyword">*&nbsp;</span><span class="syntaxdefault">n_choose_i<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;x&nbsp;</span><span class="syntaxkeyword">=&nbsp;(</span><span class="syntaxdefault">x&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">fn</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">)&nbsp;*&nbsp;</span><span class="syntaxdefault">t1<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;y&nbsp;</span><span class="syntaxkeyword">=&nbsp;(</span><span class="syntaxdefault">y&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">fn</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">y</span><span class="syntaxkeyword">)&nbsp;*&nbsp;</span><span class="syntaxdefault">t1<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;z&nbsp;</span><span class="syntaxkeyword">=&nbsp;(</span><span class="syntaxdefault">z&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">fn</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">z</span><span class="syntaxkeyword">)&nbsp;*&nbsp;</span><span class="syntaxdefault">t1<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;x&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">x&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">fact</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">t</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">degree</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">x<br />&nbsp;&nbsp;&nbsp;&nbsp;y&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">y&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">fact</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">t</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">degree</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">y<br />&nbsp;&nbsp;&nbsp;&nbsp;z&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">z&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">fact</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">t</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">degree</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">z<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Point3d</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">y</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">z</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;<br /></span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#&nbsp;method&nbsp;eval<br /><br />#&nbsp;Evaluate&nbsp;the&nbsp;curve&nbsp;at&nbsp;a&nbsp;number&nbsp;of&nbsp;points&nbsp;and&nbsp;return&nbsp;the&nbsp;points&nbsp;in&nbsp;an&nbsp;array<br /></span><span class="syntaxdefault">def&nbsp;Bezier</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">numpts</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">curvepts&nbsp;</span><span class="syntaxkeyword">=&nbsp;[]<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">dt&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">1.0&nbsp;</span><span class="syntaxkeyword">/&nbsp;</span><span class="syntaxdefault">numpts<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;evaluate&nbsp;the&nbsp;points&nbsp;on&nbsp;the&nbsp;curve<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">for&nbsp;</span><span class="syntaxdefault">i&nbsp;in&nbsp;0.</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">numpts<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;t&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">i&nbsp;</span><span class="syntaxkeyword">*&nbsp;</span><span class="syntaxdefault">dt<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;curvepts</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">]&nbsp;=&nbsp;</span><span class="syntaxdefault">Bezier</span><span class="syntaxkeyword">.eval(</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">t</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;curvepts<br />end<br /><br /></span><span class="syntaxcomment">#&nbsp;Create&nbsp;a&nbsp;Bezier&nbsp;curve&nbsp;in&nbsp;SketchUp<br /></span><span class="syntaxdefault">def&nbsp;Bezier</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">curve</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">numseg&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">16</span><span class="syntaxkeyword">)<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">model&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />&nbsp;&nbsp;&nbsp;&nbsp;entities&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities<br />&nbsp;&nbsp;&nbsp;&nbsp;model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start_operation&nbsp;</span><span class="syntaxstring">"Bezier&nbsp;Curve"<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">curvepts&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Bezier</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">numseg</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;create&nbsp;the&nbsp;curve<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">edges&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_curve</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">curvepts</span><span class="syntaxkeyword">);<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">commit_operation<br />&nbsp;&nbsp;&nbsp;&nbsp;edges<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />end<br /><br /></span><span class="syntaxcomment">#-----------------------------------------------------------------------------<br />#&nbsp;Define&nbsp;the&nbsp;tool&nbsp;class&nbsp;for&nbsp;creating&nbsp;Bezier&nbsp;curves<br /><br /></span><span class="syntaxkeyword">class&nbsp;</span><span class="syntaxdefault">BezierTool<br /><br />def&nbsp;initialize</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">degree&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">degree&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">degree<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if(&nbsp;@</span><span class="syntaxdefault">degree&nbsp;</span><span class="syntaxkeyword"><&nbsp;</span><span class="syntaxdefault">1&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">messagebox&nbsp;</span><span class="syntaxstring">"Minimum&nbsp;degree&nbsp;is&nbsp;1"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">degree&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">1<br />&nbsp;&nbsp;&nbsp;&nbsp;elsif</span><span class="syntaxkeyword">(&nbsp;@</span><span class="syntaxdefault">degree&nbsp;</span><span class="syntaxkeyword">>&nbsp;</span><span class="syntaxdefault">20&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">messagebox&nbsp;</span><span class="syntaxstring">"Maximum&nbsp;degree&nbsp;is&nbsp;20"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">degree&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">20<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;TODO;&nbsp;I&nbsp;should&nbsp;probably&nbsp;adjust&nbsp;the&nbsp;number&nbsp;of&nbsp;segments&nbsp;used&nbsp;for<br />&nbsp;&nbsp;&nbsp;&nbsp;#&nbsp;display&nbsp;and&nbsp;creating&nbsp;the&nbsp;curve&nbsp;based&nbsp;on&nbsp;the&nbsp;the&nbsp;degree&nbsp;and/or&nbsp;the<br />&nbsp;&nbsp;&nbsp;&nbsp;#&nbsp;maximum&nbsp;curvature.<br /></span><span class="syntaxdefault">end<br /><br />def&nbsp;reset<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">pts&nbsp;</span><span class="syntaxkeyword">=&nbsp;[]<br />&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">state&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0<br />&nbsp;&nbsp;&nbsp;&nbsp;Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">set_status_text&nbsp;</span><span class="syntaxstring">"Click&nbsp;for&nbsp;start&nbsp;point"<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">drawn&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">false<br />end<br /><br />def&nbsp;activate<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;There&nbsp;are&nbsp;up&nbsp;to&nbsp;4&nbsp;input&nbsp;points&nbsp;that&nbsp;we&nbsp;keep&nbsp;track&nbsp;of<br />&nbsp;&nbsp;&nbsp;&nbsp;#&nbsp;@ip1&nbsp;is&nbsp;the&nbsp;start&nbsp;point&nbsp;of&nbsp;the&nbsp;curve<br />&nbsp;&nbsp;&nbsp;&nbsp;#&nbsp;@ip2&nbsp;is&nbsp;the&nbsp;endpoint&nbsp;of&nbsp;the&nbsp;curve<br />&nbsp;&nbsp;&nbsp;&nbsp;#&nbsp;@ip3&nbsp;is&nbsp;the&nbsp;second&nbsp;control&nbsp;point.&nbsp;&nbsp;It&nbsp;determines&nbsp;the&nbsp;tangency&nbsp;at&nbsp;the&nbsp;start<br />&nbsp;&nbsp;&nbsp;&nbsp;#&nbsp;@ip4&nbsp;is&nbsp;the&nbsp;next&nbsp;to&nbsp;last&nbsp;control&nbsp;point.&nbsp;&nbsp;It&nbsp;determines&nbsp;the&nbsp;tangency&nbsp;at&nbsp;the&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;#&nbsp;@ip5&nbsp;is&nbsp;an&nbsp;internal&nbsp;input&nbsp;point<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">ip1&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">InputPoint</span><span class="syntaxkeyword">.new<br />&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">ip2&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">InputPoint</span><span class="syntaxkeyword">.new<br />&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">ip3&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">InputPoint</span><span class="syntaxkeyword">.new<br />&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">ip4&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">InputPoint</span><span class="syntaxkeyword">.new<br />&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">ip5&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">InputPoint</span><span class="syntaxkeyword">.new<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;@ip&nbsp;is&nbsp;a&nbsp;temporary&nbsp;input&nbsp;point&nbsp;used&nbsp;to&nbsp;get&nbsp;other&nbsp;positions<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">ip&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">InputPoint</span><span class="syntaxkeyword">.new<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">reset<br />&nbsp;&nbsp;&nbsp;&nbsp;Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">set_status_text&nbsp;</span><span class="syntaxstring">"Degree"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">SB_VCB_LABEL<br />&nbsp;&nbsp;&nbsp;&nbsp;Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">set_status_text&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">degree</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">SB_VCB_VALUE<br />end<br /><br />def&nbsp;deactivate</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">invalidate&nbsp;</span><span class="syntaxkeyword">if&nbsp;@</span><span class="syntaxdefault">drawn<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">ip1&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">nil<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">ip2&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">nil<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">ip3&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">nil<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">ip4&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">nil<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">ip5&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">nil<br />end<br /><br />def&nbsp;onMouseMove</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">flags</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">y</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;case&nbsp;@</span><span class="syntaxdefault">state<br />&nbsp;&nbsp;&nbsp;&nbsp;when&nbsp;0&nbsp;</span><span class="syntaxcomment">#&nbsp;getting&nbsp;the&nbsp;first&nbsp;end&nbsp;point<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pick&nbsp;view</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">y<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if(&nbsp;@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">valid</span><span class="syntaxkeyword">?&nbsp;&&&nbsp;@</span><span class="syntaxdefault">ip&nbsp;</span><span class="syntaxkeyword">!=&nbsp;@</span><span class="syntaxdefault">ip1&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">ip1</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">copy</span><span class="syntaxkeyword">!&nbsp;@</span><span class="syntaxdefault">ip<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">invalidate<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;when&nbsp;1&nbsp;</span><span class="syntaxcomment">#&nbsp;getting&nbsp;the&nbsp;second&nbsp;end&nbsp;point<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pick&nbsp;view</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">y</span><span class="syntaxkeyword">,&nbsp;@</span><span class="syntaxdefault">ip1<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if(&nbsp;@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">valid</span><span class="syntaxkeyword">?&nbsp;&&&nbsp;@</span><span class="syntaxdefault">ip&nbsp;</span><span class="syntaxkeyword">!=&nbsp;@</span><span class="syntaxdefault">ip2&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">ip2</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">copy</span><span class="syntaxkeyword">!&nbsp;@</span><span class="syntaxdefault">ip<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">]&nbsp;=&nbsp;@</span><span class="syntaxdefault">ip2</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">invalidate<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;when&nbsp;2&nbsp;</span><span class="syntaxcomment">#&nbsp;the&nbsp;second&nbsp;control&nbsp;point&nbsp;-&nbsp;tangency&nbsp;at&nbsp;start<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pick&nbsp;view</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">y</span><span class="syntaxkeyword">,&nbsp;@</span><span class="syntaxdefault">ip1<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if(&nbsp;@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">valid</span><span class="syntaxkeyword">?&nbsp;&&&nbsp;@</span><span class="syntaxdefault">ip&nbsp;</span><span class="syntaxkeyword">!=&nbsp;@</span><span class="syntaxdefault">ip3&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">ip3</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">copy</span><span class="syntaxkeyword">!&nbsp;@</span><span class="syntaxdefault">ip<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">]&nbsp;=&nbsp;@</span><span class="syntaxdefault">ip3</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">invalidate<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;when&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">degree&nbsp;</span><span class="syntaxcomment">#&nbsp;the&nbsp;next&nbsp;to&nbsp;last&nbsp;point&nbsp;=&nbsp;tangency&nbsp;at&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pick&nbsp;view</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">y</span><span class="syntaxkeyword">,&nbsp;@</span><span class="syntaxdefault">ip2<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if(&nbsp;@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">valid</span><span class="syntaxkeyword">?&nbsp;&&&nbsp;@</span><span class="syntaxdefault">ip&nbsp;</span><span class="syntaxkeyword">!=&nbsp;@</span><span class="syntaxdefault">ip4&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">ip4</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">copy</span><span class="syntaxkeyword">!&nbsp;@</span><span class="syntaxdefault">ip<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[@</span><span class="syntaxdefault">degree</span><span class="syntaxkeyword">-</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">]&nbsp;=&nbsp;@</span><span class="syntaxdefault">ip4</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">invalidate<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;when&nbsp;3.</span><span class="syntaxkeyword">.@</span><span class="syntaxdefault">degree</span><span class="syntaxkeyword">-</span><span class="syntaxdefault">1&nbsp;</span><span class="syntaxcomment">#&nbsp;internal&nbsp;points&nbsp;-&nbsp;if&nbsp;degree&nbsp;>&nbsp;3<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pick&nbsp;view</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">y<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if(&nbsp;@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">valid</span><span class="syntaxkeyword">?&nbsp;&&&nbsp;@</span><span class="syntaxdefault">ip&nbsp;</span><span class="syntaxkeyword">!=&nbsp;@</span><span class="syntaxdefault">ip5&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">ip5</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">copy</span><span class="syntaxkeyword">!&nbsp;@</span><span class="syntaxdefault">ip<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[@</span><span class="syntaxdefault">state</span><span class="syntaxkeyword">-</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">]&nbsp;=&nbsp;@</span><span class="syntaxdefault">ip5</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">invalidate<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">tooltip&nbsp;</span><span class="syntaxkeyword">=&nbsp;@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">tooltip&nbsp;</span><span class="syntaxkeyword">if&nbsp;@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">valid</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">end<br /><br />def&nbsp;create_curve<br />&nbsp;&nbsp;&nbsp;&nbsp;curve&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Bezier</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">curve&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">20<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;see&nbsp;if&nbsp;this&nbsp;fills&nbsp;in&nbsp;any&nbsp;new&nbsp;faces<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if(&nbsp;</span><span class="syntaxdefault">curve&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">edge1&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">curve</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">edge1</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find_faces<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Attach&nbsp;an&nbsp;attribute&nbsp;to&nbsp;the&nbsp;curve&nbsp;with&nbsp;the&nbsp;array&nbsp;of&nbsp;points<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">curve&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">edge1</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">curve<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if(&nbsp;</span><span class="syntaxdefault">curve&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">curve</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_attribute&nbsp;</span><span class="syntaxstring">"skp"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"crvtype"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"Bezier"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">curve</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_attribute&nbsp;</span><span class="syntaxstring">"skp"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"crvpts"</span><span class="syntaxkeyword">,&nbsp;@</span><span class="syntaxdefault">pts<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">reset<br />end<br /><br />def&nbsp;onLButtonDown</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">flags</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">y</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;TODO;&nbsp;Use&nbsp;the&nbsp;two&nbsp;point&nbsp;form&nbsp;of&nbsp;the&nbsp;input&nbsp;point&nbsp;finder&nbsp;to&nbsp;get&nbsp;the&nbsp;new&nbsp;points.<br />&nbsp;&nbsp;&nbsp;&nbsp;#&nbsp;I&nbsp;need&nbsp;a&nbsp;way&nbsp;to&nbsp;generate&nbsp;an&nbsp;ip&nbsp;at&nbsp;a&nbsp;given&nbsp;position&nbsp;from&nbsp;code.<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pick&nbsp;view</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">y<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if(&nbsp;@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">valid</span><span class="syntaxkeyword">?&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;case&nbsp;@</span><span class="syntaxdefault">state<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&nbsp;0<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]&nbsp;=&nbsp;@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">set_status_text&nbsp;</span><span class="syntaxstring">"Click&nbsp;for&nbsp;end&nbsp;point"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">state&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">1<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">degree<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">create_curve<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&nbsp;1<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">]&nbsp;=&nbsp;@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">state&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">2<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">set_status_text&nbsp;</span><span class="syntaxstring">"Click&nbsp;for&nbsp;point&nbsp;2"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">when&nbsp;2.</span><span class="syntaxkeyword">..@</span><span class="syntaxdefault">degree<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;nextstate&nbsp;</span><span class="syntaxkeyword">=&nbsp;@</span><span class="syntaxdefault">state</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">1<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">nextstate</span><span class="syntaxkeyword">]&nbsp;=&nbsp;@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[@</span><span class="syntaxdefault">state</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[@</span><span class="syntaxdefault">state</span><span class="syntaxkeyword">]&nbsp;=&nbsp;@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">state&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">nextstate<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">set_status_text&nbsp;</span><span class="syntaxstring">"Click&nbsp;for&nbsp;point&nbsp;#{@state}"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br />end<br /><br />def&nbsp;onCancel</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">flag</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">invalidate&nbsp;</span><span class="syntaxkeyword">if&nbsp;@</span><span class="syntaxdefault">drawn<br />&nbsp;&nbsp;&nbsp;&nbsp;reset<br />end<br /><br />def&nbsp;onUserText</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">text</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;get&nbsp;the&nbsp;degree&nbsp;from&nbsp;the&nbsp;text<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">newdegree&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">text</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_i<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if(&nbsp;</span><span class="syntaxdefault">newdegree&nbsp;</span><span class="syntaxkeyword">>&nbsp;</span><span class="syntaxdefault">0&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">degree&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">newdegree<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">create_curve&nbsp;</span><span class="syntaxkeyword">if(&nbsp;@</span><span class="syntaxdefault">state&nbsp;</span><span class="syntaxkeyword">>&nbsp;@</span><span class="syntaxdefault">degree&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;else<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">beep<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">set_status_text&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">degree</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">SB_VCB_VALUE<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br />end<br /><br />def&nbsp;getExtents<br />&nbsp;&nbsp;&nbsp;&nbsp;bb&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">BoundingBox</span><span class="syntaxkeyword">.new<br />&nbsp;&nbsp;&nbsp;&nbsp;if(&nbsp;@</span><span class="syntaxdefault">state&nbsp;</span><span class="syntaxkeyword">==&nbsp;</span><span class="syntaxdefault">0&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;We&nbsp;are&nbsp;getting&nbsp;the&nbsp;first&nbsp;point<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if(&nbsp;@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">valid</span><span class="syntaxkeyword">?&nbsp;&&&nbsp;@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">display</span><span class="syntaxkeyword">?&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">bb</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">else<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">bb</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">pts<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;bb<br />end<br /><br />def&nbsp;draw</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">)<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Show&nbsp;the&nbsp;current&nbsp;input&nbsp;point<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if(&nbsp;@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">valid</span><span class="syntaxkeyword">?&nbsp;&&&nbsp;@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">display</span><span class="syntaxkeyword">?&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">draw</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">drawn&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">true<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;show&nbsp;the&nbsp;curve<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if(&nbsp;@</span><span class="syntaxdefault">state&nbsp;</span><span class="syntaxkeyword">==&nbsp;</span><span class="syntaxdefault">1&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;just&nbsp;draw&nbsp;a&nbsp;line&nbsp;from&nbsp;the&nbsp;start&nbsp;to&nbsp;the&nbsp;end&nbsp;point<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_color_from_line</span><span class="syntaxkeyword">(@</span><span class="syntaxdefault">ip1</span><span class="syntaxkeyword">,&nbsp;@</span><span class="syntaxdefault">ip2</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">draw</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">GL_LINE_STRIP</span><span class="syntaxkeyword">,&nbsp;@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">drawn&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">true<br />&nbsp;&nbsp;&nbsp;&nbsp;elsif</span><span class="syntaxkeyword">(&nbsp;@</span><span class="syntaxdefault">state&nbsp;</span><span class="syntaxkeyword">>&nbsp;</span><span class="syntaxdefault">1&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;draw&nbsp;the&nbsp;curve<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">drawing_color&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">"black"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">curvepts&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Bezier</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">(@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">12</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">draw</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">GL_LINE_STRIP</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">curvepts</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;draw&nbsp;the&nbsp;control&nbsp;polygon<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#&nbsp;determine&nbsp;the&nbsp;colos&nbsp;for&nbsp;the&nbsp;first&nbsp;and&nbsp;last&nbsp;segments&nbsp;from&nbsp;the&nbsp;input&nbsp;points<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">case&nbsp;@</span><span class="syntaxdefault">state<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&nbsp;2<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_color_from_line</span><span class="syntaxkeyword">(@</span><span class="syntaxdefault">ip1</span><span class="syntaxkeyword">,&nbsp;@</span><span class="syntaxdefault">ip3</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">draw</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">GL_LINE_STRIP</span><span class="syntaxkeyword">,&nbsp;@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">],&nbsp;@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">])<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">drawing_color&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">"gray"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">draw</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">GL_LINE_STRIP</span><span class="syntaxkeyword">,&nbsp;@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1.</span><span class="syntaxkeyword">.-</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">])<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">when&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">degree<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">drawing_color&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">"gray"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">draw</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">GL_LINE_STRIP</span><span class="syntaxkeyword">,&nbsp;@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0.</span><span class="syntaxkeyword">.-</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">])<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_color_from_line</span><span class="syntaxkeyword">(@</span><span class="syntaxdefault">ip2</span><span class="syntaxkeyword">,&nbsp;@</span><span class="syntaxdefault">ip4</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">draw</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">GL_LINE_STRIP</span><span class="syntaxkeyword">,&nbsp;@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[@</span><span class="syntaxdefault">degree</span><span class="syntaxkeyword">-</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">],&nbsp;@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[@</span><span class="syntaxdefault">degree</span><span class="syntaxkeyword">])<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;else<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">drawing_color&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">"gray"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">draw</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">GL_LINE_STRIP</span><span class="syntaxkeyword">,&nbsp;@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">drawn&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">true<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br />end<br /><br />end&nbsp;</span><span class="syntaxcomment">#&nbsp;class&nbsp;BezierTool<br /><br />#-----------------------------------------------------------------------------<br />#&nbsp;Define&nbsp;the&nbsp;tool&nbsp;class&nbsp;for&nbsp;editing&nbsp;Bezier&nbsp;curves<br /><br /></span><span class="syntaxkeyword">class&nbsp;</span><span class="syntaxdefault">EditBezierTool<br /><br />def&nbsp;activate<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">state&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">drawn&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">false<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">selection&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">nil<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">pt_to_move&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">nil<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Make&nbsp;sure&nbsp;that&nbsp;there&nbsp;is&nbsp;really&nbsp;a&nbsp;Bezier&nbsp;curve&nbsp;selected<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">curve&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Bezier</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selected_curve<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if(&nbsp;</span><span class="syntaxdefault">not&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">curve&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select_tool&nbsp;nil<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">return<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Get&nbsp;the&nbsp;control&nbsp;points<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">pts&nbsp;</span><span class="syntaxkeyword">=&nbsp;@</span><span class="syntaxdefault">curve</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute&nbsp;</span><span class="syntaxstring">"skp"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"crvpts"<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if(&nbsp;</span><span class="syntaxdefault">not&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">pts&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">beep<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select_tool&nbsp;nil<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">return<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Get&nbsp;the&nbsp;curve&nbsp;points&nbsp;from&nbsp;the&nbsp;vertices<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">vertices&nbsp;</span><span class="syntaxkeyword">=&nbsp;@</span><span class="syntaxdefault">curve</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">vertices<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">crvpts&nbsp;</span><span class="syntaxkeyword">=&nbsp;@</span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">collect&nbsp;</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">v</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">v</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">numseg&nbsp;</span><span class="syntaxkeyword">=&nbsp;@</span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length&nbsp;</span><span class="syntaxkeyword">-&nbsp;</span><span class="syntaxdefault">1<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">ip&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">InputPoint</span><span class="syntaxkeyword">.new<br /></span><span class="syntaxdefault">end<br /><br />def&nbsp;deactivate</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">invalidate&nbsp;</span><span class="syntaxkeyword">if&nbsp;@</span><span class="syntaxdefault">drawn<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">ip&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">nil<br />end<br /><br />def&nbsp;resume</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">drawn&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">false<br />end<br /><br />def&nbsp;pick_point_to_move</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">y</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">old_pt_to_move&nbsp;</span><span class="syntaxkeyword">=&nbsp;@</span><span class="syntaxdefault">pt_to_move<br />&nbsp;&nbsp;&nbsp;&nbsp;ph&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pick_helper&nbsp;x</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">y<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">selection&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">ph</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pick_segment&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">pts<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if(&nbsp;@</span><span class="syntaxdefault">selection&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if(&nbsp;@</span><span class="syntaxdefault">selection&nbsp;</span><span class="syntaxkeyword"><&nbsp;</span><span class="syntaxdefault">0&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;We&nbsp;got&nbsp;a&nbsp;point&nbsp;on&nbsp;a&nbsp;segment.&nbsp;&nbsp;Compute&nbsp;the&nbsp;point&nbsp;closest<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#&nbsp;to&nbsp;the&nbsp;pick&nbsp;ray.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">pickray&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pickray&nbsp;x</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">y<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;i&nbsp;</span><span class="syntaxkeyword">=&nbsp;-@</span><span class="syntaxdefault">selection<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;segment&nbsp;</span><span class="syntaxkeyword">=&nbsp;[@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">-</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">],&nbsp;@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">]]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">result&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">closest_points&nbsp;segment</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">pickray<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">pt_to_move&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">result</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;else<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;we&nbsp;got&nbsp;a&nbsp;control&nbsp;point<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">pt_to_move&nbsp;</span><span class="syntaxkeyword">=&nbsp;@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[@</span><span class="syntaxdefault">selection</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">else<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">pt_to_move&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">nil<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;old_pt_to_move&nbsp;</span><span class="syntaxkeyword">!=&nbsp;@</span><span class="syntaxdefault">pt_to_move<br />end<br /><br />def&nbsp;onLButtonDown</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">flags</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">y</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Select&nbsp;the&nbsp;segment&nbsp;or&nbsp;control&nbsp;point&nbsp;to&nbsp;move<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pick_point_to_move&nbsp;x</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">y</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">view<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">state&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">1&nbsp;</span><span class="syntaxkeyword">if(&nbsp;@</span><span class="syntaxdefault">selection&nbsp;</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">end<br /><br />def&nbsp;onLButtonUp</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">flags</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">y</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;return&nbsp;if&nbsp;</span><span class="syntaxdefault">not&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">state&nbsp;</span><span class="syntaxkeyword">==&nbsp;</span><span class="syntaxdefault">1<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">state&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Update&nbsp;the&nbsp;actual&nbsp;curve.&nbsp;&nbsp;Move&nbsp;the&nbsp;vertices&nbsp;on&nbsp;the&nbsp;curve<br />&nbsp;&nbsp;&nbsp;&nbsp;#&nbsp;to&nbsp;the&nbsp;new&nbsp;curve&nbsp;points<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if(&nbsp;@</span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length&nbsp;</span><span class="syntaxkeyword">!=&nbsp;@</span><span class="syntaxdefault">crvpts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">messagebox&nbsp;</span><span class="syntaxstring">"Count&nbsp;of&nbsp;curve&nbsp;points&nbsp;is&nbsp;wrong!"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">return<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;model&nbsp;</span><span class="syntaxkeyword">=&nbsp;@</span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">model<br />&nbsp;&nbsp;&nbsp;&nbsp;model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start_operation&nbsp;</span><span class="syntaxstring">"Edit&nbsp;Bezier&nbsp;Curve"<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Move&nbsp;the&nbsp;vertices<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">curve</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">move_vertices&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">crvpts<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Update&nbsp;the&nbsp;control&nbsp;points&nbsp;stored&nbsp;with&nbsp;the&nbsp;curve<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">curve</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_attribute&nbsp;</span><span class="syntaxstring">"skp"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"crvpts"</span><span class="syntaxkeyword">,&nbsp;@</span><span class="syntaxdefault">pts<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">commit_operation<br />end<br /><br />def&nbsp;onMouseMove</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">flags</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">y</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Make&nbsp;sure&nbsp;that&nbsp;the&nbsp;control&nbsp;polygon&nbsp;is&nbsp;shown<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">invalidate&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">not&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">drawn<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Move&nbsp;the&nbsp;selected&nbsp;point&nbsp;if&nbsp;state&nbsp;=&nbsp;1<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if(&nbsp;@</span><span class="syntaxdefault">state&nbsp;</span><span class="syntaxkeyword">==&nbsp;</span><span class="syntaxdefault">1&nbsp;</span><span class="syntaxkeyword">&&&nbsp;@</span><span class="syntaxdefault">selection&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pick&nbsp;view</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">y<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">return&nbsp;if&nbsp;</span><span class="syntaxdefault">not&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">valid</span><span class="syntaxkeyword">?<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if(&nbsp;@</span><span class="syntaxdefault">selection&nbsp;</span><span class="syntaxkeyword">>=&nbsp;</span><span class="syntaxdefault">0&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Moving&nbsp;a&nbsp;control&nbsp;point<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">pt_to_move&nbsp;</span><span class="syntaxkeyword">=&nbsp;@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[@</span><span class="syntaxdefault">selection</span><span class="syntaxkeyword">]&nbsp;=&nbsp;@</span><span class="syntaxdefault">pt_to_move<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">else<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;moving&nbsp;a&nbsp;segment<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">pt&nbsp;</span><span class="syntaxkeyword">=&nbsp;@</span><span class="syntaxdefault">ip</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;vec&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">pt&nbsp;</span><span class="syntaxkeyword">-&nbsp;@</span><span class="syntaxdefault">pt_to_move<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;i&nbsp;</span><span class="syntaxkeyword">=&nbsp;-@</span><span class="syntaxdefault">selection<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">-</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">offset</span><span class="syntaxkeyword">!&nbsp;</span><span class="syntaxdefault">vec<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">offset</span><span class="syntaxkeyword">!&nbsp;</span><span class="syntaxdefault">vec<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">pt_to_move&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">pt<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">crvpts&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Bezier</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">(@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">,&nbsp;@</span><span class="syntaxdefault">numseg</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">invalidate<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">else&nbsp;</span><span class="syntaxcomment">#&nbsp;state&nbsp;!=&nbsp;1<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#&nbsp;See&nbsp;if&nbsp;we&nbsp;can&nbsp;select&nbsp;something&nbsp;to&nbsp;move<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">invalidate&nbsp;</span><span class="syntaxkeyword">if(&nbsp;</span><span class="syntaxdefault">self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pick_point_to_move</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">y</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">)&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />end<br /><br />def&nbsp;getMenu</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Done"</span><span class="syntaxkeyword">)&nbsp;{</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select_tool&nbsp;nil</span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">end<br /><br />def&nbsp;getExtents<br />&nbsp;&nbsp;&nbsp;&nbsp;bb&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">BoundingBox</span><span class="syntaxkeyword">.new<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">bb</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">pts<br />&nbsp;&nbsp;&nbsp;&nbsp;bb<br />end<br /><br />def&nbsp;draw</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Draw&nbsp;the&nbsp;control&nbsp;polygon<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">drawing_color&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">"gray"<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">draw</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">GL_LINE_STRIP</span><span class="syntaxkeyword">,&nbsp;@</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;if(&nbsp;@</span><span class="syntaxdefault">pt_to_move&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">draw_points</span><span class="syntaxkeyword">(@</span><span class="syntaxdefault">pt_to_move</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">10</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"red"</span><span class="syntaxkeyword">);<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if(&nbsp;@</span><span class="syntaxdefault">state&nbsp;</span><span class="syntaxkeyword">==&nbsp;</span><span class="syntaxdefault">1&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">drawing_color&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">"black"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">draw</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">GL_LINE_STRIP</span><span class="syntaxkeyword">,&nbsp;@</span><span class="syntaxdefault">crvpts</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">drawn&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">true<br />end<br /><br />end&nbsp;</span><span class="syntaxcomment">#&nbsp;class&nbsp;EditBezierTool<br /><br />#-----------------------------------------------------------------------------<br /><br />#&nbsp;Function&nbsp;to&nbsp;test&nbsp;to&nbsp;see&nbsp;if&nbsp;the&nbsp;selection&nbsp;set&nbsp;contains&nbsp;only&nbsp;a&nbsp;Bezier&nbsp;curve<br />#&nbsp;Returns&nbsp;the&nbsp;curve&nbsp;if&nbsp;there&nbsp;is&nbsp;one&nbsp;or&nbsp;else&nbsp;nil<br /></span><span class="syntaxdefault">def&nbsp;Bezier</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selected_curve<br />&nbsp;&nbsp;&nbsp;&nbsp;ss&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">return&nbsp;</span><span class="syntaxdefault">nil&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">not&nbsp;ss</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_curve</span><span class="syntaxkeyword">?<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">edge&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">ss</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">first<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">return&nbsp;</span><span class="syntaxdefault">nil&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">not&nbsp;edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">kind_of</span><span class="syntaxkeyword">?&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Edge<br />&nbsp;&nbsp;&nbsp;&nbsp;curve&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">curve<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">return&nbsp;</span><span class="syntaxdefault">nil&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">not&nbsp;curve<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">return&nbsp;</span><span class="syntaxdefault">nil&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">curve</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"skp"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"crvtype"</span><span class="syntaxkeyword">)&nbsp;!=&nbsp;</span><span class="syntaxstring">"Bezier"<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">curve<br />end<br /><br /></span><span class="syntaxcomment">#&nbsp;Edit&nbsp;a&nbsp;selected&nbsp;Bezier&nbsp;curve<br /></span><span class="syntaxdefault">def&nbsp;Bezier</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">edit_curve<br />&nbsp;&nbsp;&nbsp;&nbsp;curve&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Bezier</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selected_curve<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if(&nbsp;</span><span class="syntaxdefault">not&nbsp;curve&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">beep<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">return<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;&nbsp;&nbsp;Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select_tool&nbsp;EditBezierTool</span><span class="syntaxkeyword">.new<br /></span><span class="syntaxdefault">end<br /><br /></span><span class="syntaxcomment">#&nbsp;Select&nbsp;the&nbsp;Bezier&nbsp;curve&nbsp;tool<br /></span><span class="syntaxdefault">def&nbsp;Bezier</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">tool</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">degree</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select_tool&nbsp;BezierTool</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault">degree</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">end<br /><br /></span><span class="syntaxcomment">#&nbsp;Add&nbsp;a&nbsp;menu&nbsp;choice&nbsp;for&nbsp;creating&nbsp;bezier&nbsp;curves<br /></span><span class="syntaxkeyword">if(&nbsp;</span><span class="syntaxdefault">not&nbsp;file_loaded</span><span class="syntaxkeyword">?(</span><span class="syntaxstring">"bezier.rb"</span><span class="syntaxkeyword">)&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">add_separator_to_menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Draw"</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Draw"</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Bezier&nbsp;Curves"</span><span class="syntaxkeyword">)&nbsp;{&nbsp;</span><span class="syntaxdefault">Bezier</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">tool&nbsp;</span><span class="syntaxkeyword">}<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Add&nbsp;a&nbsp;context&nbsp;menu&nbsp;handler&nbsp;to&nbsp;let&nbsp;you&nbsp;edit&nbsp;a&nbsp;Bezier&nbsp;curve<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_context_menu_handler&nbsp;</span><span class="syntaxkeyword">do&nbsp;|</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if(&nbsp;</span><span class="syntaxdefault">Bezier</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selected_curve&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_separator<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;menu</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Edit&nbsp;Bezier&nbsp;Curve"</span><span class="syntaxkeyword">)&nbsp;{&nbsp;</span><span class="syntaxdefault">Bezier</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">edit_curve&nbsp;</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br /><br />end<br /><br />end&nbsp;</span><span class="syntaxcomment">#&nbsp;module&nbsp;Bezier<br /></span><span class="syntaxdefault">file_loaded</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"bezier.rb"</span><span class="syntaxkeyword">)&nbsp;</span><span class="syntaxdefault"></span>
        Have you tried Fredo's bezier and spline plugin?
        http://sketchucation.com/forums/viewtopic.php?t=13563
        Offer lots more control and options.
        • Dan RathbunD Offline
          Dan Rathbun
          Simple ... referring to the line numbers in the post above:
          Change line 86 from:
          def Bezier.curve(pts, numseg = 16)
          to:
          def Bezier.curve(pts, numseg = 100)
          (Use whatever default number of segments you want.)
          THEN remove the comma and explicit second parameter ( 20) from the where that method is called in the tool, on (or about) line 196, ie:
          curve = Bezier.curve @pts, 20
          becomes:
          I'm not here much anymore.
          • piratebrianP Offline
            piratebrian
            Awesome Dan!
            Thanks, I'll try it.
            I'll read up on the Newbie's guide as well.
              piratebrian
              I'll post some cut tests shortly, but here is the lovely curve:
