    Sketchup to Lumion - Material Problem
    extensions
    7 Posts 4 Posters 10.0k Views 4 Watching
      ramonbastos
      Hi guys, sometimes when i import a model from sketchup to lumion, some faces come "brown'.
      Here is an image to show:
      http://i46.tinypic.com/2ztk3nk.jpg
      The roof is supposed to be white, as it is in the sketchup file:
      http://i46.tinypic.com/2hobp5j.png
      Anybody knows why is it happening?
      • soloS Offline
        solo
        It's not a material issue, it's a GI issue. What version of Lumion do you have? As the new version is tailored more for interiors and there are tools to get interiors right.
        The quick fix (if your roof is a separate material) is to give it a very slight emissive value, or use the AO tools that come with new version (I do not have the new version so I cannot help)
        http://www.solos-art.com
          ramonbastos
          Yeah it´s possible to "fix" by adding emissivity, but it gets kinda weird..
          I have lumion 3. What do you mean by AO tools?
          • soloS Offline
            solo
            In your movie effects options there is one called Global Illumination, There you can set sun effects, which will fix the ceiling, again I do not have this version so I cannot really help much, if you go to the Lumion forum they will help you better.
            • 1 Offline
              1996aditn
              Even i am facing the same issue in lumion-8. Have you found the solution? please help me out.
              • 1 Offline
                1996aditn
                Hii guys! please help me out. sketchup to lumion 8 material issue.
                • jujuJ Offline
                  juju
                  check in Sketchup what the face orientation may be, i.e. if those are oreinted correctly and not backfaces
