    To detect if a component contains a component
    5 Posts 3 Posters 380 Views 3 Watching
    • G Offline
      glro
      i am wondering if there is a way to detect if a component contains an embedded component
      the idea is:
      if it contains an embedded component, explode it
      if not, don't explode it
      There is a simple way: add some characters at the end of the component name, and check wether these characters exist
      model = Sketchup.active_model # Open model
      entities = model.entities # All entities in model
      entities.to_a
      model.start_operation "explose_comp_imbriques"
      for e in entities.to_a
            if e.is_a? Sketchup;;ComponentInstance
                str= e.definition.name
                e.explode if (str.include? "#i" )
      Sketchup.active_model.definitions.purge_unused
      model.commit_operation
      but it would be better not to be obliged to add special characters
        This explodes all component-instances that contain another instance AND clears the now unused definitions
        model=Sketchup.active_model
        defns=model.definitions
        model.start_operation('xxx!')
        defns.each{|d|
          next unless d.instances[0]
          nested=false
          d.entities.each{|e|
            if e.is_a?(Sketchup;;ComponentInstance)
              nested=true
              break
          d.instances.each{|i| i.explode } if nested
        defns.each{|d|
          d.entities.clear! unless d.instances[0]
        Is it what you really want to do ?
        It is one step undo-able,
        It's only partial coder - it needs to be wrapped in a module/method etc of your choice...
        ` module Giro
        def self.xxx()
        the code goes here
        end#def
        end#moduleUsage: in the Ruby Console: Giro.xxx`
        Change 'xxx' to be whatever suits you...
        • Dan RathbunD Offline
          Dan Rathbun
          Here's another edition (wrapped in method,) that only works upon the active editing context (to help prevent BugSplats!,) tests first for any definitions and lastly filters out images and groups.
          Also adds in a begin ... rescue block.
          @dan rathbun said:
          ...snip... (WIP) found errors
          Actually it may be correct. (No food yet today.)
          Not thoroughly tested.
          def explode_parent_components()
            context = model.active_entities
            if context.any?{|e| Sketchup;;ComponentInstance === e }
              defns = model.definitions.find_all{|d| !d.image? && !d.group? }
              if defns.any?
                begin
                  op = 'Explode ONLY Parent Components'
                  if model.method(;start_operation).arity==1
                    model.start_operation(op)
                  else
                    model.start_operation(op,true) # disable UI on SU 7+
                    defns.each{|d|
                      inst = d.instances
                      next if inst.empty?
                      inst.reject!{|i| i.parent != context }
                      inst.each{|i| i.explode }
                  model.commit_operation()
                rescue => e
                  model.abort_operation()
                  UI.messagebox($!.message) if $VERBOSE
                  raise()
              end # if any defns
            end # if any instances in the active context
          end # def
          I'm not here much anymore.
          • G Offline
            glro
            It works perfectly
            thank you!
            • G Offline
              glro
              thank you for the code
              i tried it, but it doesn't work, at least on my computer
