Rough edges
hi all hope you well
using sketchup 8 free
is there any way to get a rough edge on a wall, eg when using a rock texture nothing
looks worse than a razor sharp edge.thanks shaun
Hi Shaun,
Not in SketchUp unless you model the edges with the stones/brock of the masonry. Many use external rendering software here however that can do "displacement" on the walls.
Now if you only want to round the edges a bit and wrap the material around those rounded corners, that1s of course possible. If that could be a solution, here is a plugin: http://sketchucation.com/forums/viewtopic.php?t=20485
hi Gaieus
thanks for your quick reply, i will give that a try.
cheers shuan
Register LoginAdvertisement
