    Adding groups to an existing group
    3 Posts 2 Posters 351 Views 2 Watching
    • sdmitchS
      sdmitch
      What am I missing. When the following code is executed it creates groups from each face but grpA, which I thought I was adding groups to, is empty?
      mod = Sketchup.active_model
      ent = mod.active_entities
      sel = mod.selection
      grpA = ent.add_group; grpA.name="container"
      for f in ent.grep(Sketchup;;Face)
       grpB=grpA.entities.add_group f
       grpB.name="#{f.bounds.width} X #{f.bounds.height}"
      puts "grpA contains #{grpA.entities.length} entities"
      http://sdmitch.blogspot.com/
      • TIGT
        The ' entities.add_group(xxx)' ONLY works if the ' xxx' is in the ' active_entities' AND ' entities' IS the ' active_entities'...
        So you need to add those faces [that are also in the ' active_entities'] directly into a group as you add it into the ' active_entities', then add that new group directly into a second group that you then add into the ' active_entities' etc...
        Otherwise get a references to the group and use something like:
        tr=Geom::Transformation.new()another_things_entities.add_instance(group.entities.parent, tr)
        then erase the original group
        group.erase!
        leaving a 'clone' of it inside this other group...
        You are lucky not to get a Bugsplat when 'crossing entities' ๐Ÿ˜ฎ
        • sdmitchS
          sdmitch
          Thanks TIG. I sure there is a logical explination as to why you have to add an instance to the container group and delete the original but seems strange to me. Anyway, using your suggestions, this is the modified code and it works just like I wanted.
          sel = mod.selection
          tr=Geom;;Transformation.new()
           grpB=ent.add_group f; tr=grpB.transformation
           grpC=grpA.entities.add_instance(grpB.entities.parent,tr)
           grpC.name=grpB.name
           grpB.erase!
