Grey line objects turn black in LO
I have a problem with some objects i created using grey lines in sketchup. I use the shaded with textures style with colors set to material. When I export drawing to layout the lines turn black. A couple of weeks ago I made a drawing and exported it to Layout without a problem. Is there a way to see which style setting has been chosen in sketchup? I have the feeling the problem is in the style settings.
Make sure you have saved the style you want and have it set with the scene update, and saved the SU file. In LO set the reference to the Scene.
Another issue might cause the style not to be set correctly== if your scene is set NOT to remember styles.
Register LoginAdvertisement
