    Offset Curve in Dynamic Component?
    3 Posts 2 Posters 845 Views 2 Watching
    • E
      Eric_J
      Hello
      Apologies if this has been asked and answered elsewhere....
      Is it possible to embed a fixed offset function - or variable offset, for that matter - in a dynamic component?
      For example, I'd like to be able to have a complex curve in 2D with a similar curve offset so that when X or Y is scaled on the main curve, the perpendicular distance on the offset curve stays the same.
      Can this be done? Does it need scripting?
      Thanks for any thoughts...
      EJ
      • DareDevilD
        DareDevil
        @eric_j said:
        Hello
        EJ
        With DC, you can copy, move, rotate and scale a shape but you can't make an offset.
        If you need to do this dynamically, I think you must script in Ruby.
        • E
          Eric_J
          @daredevil said:
          @eric_j said:
          Hello
          EJ
          Didier
          Thanks; that's what I suspected....
