    Dynamic Window -multiple animations
    6 Posts 3 Posters 1.3k Views 3 Watching
    • Epix3DE
      Epix3D
      This window opens when clicked on, -but what I am trying to do is that the opening frame also slides down in position while opening like the one on picture(mechanics not present)
      Any help appreciated.
      Dynamic Window.skp
      • Epix3DE
        Epix3D
        ..Dooh! Just found out I forgot to set the line "Z =Position"
        • KrisidiousK
          Krisidious
          Love to have the final version... That's pretty sweet.
          By: Kristoff Rand
          • Epix3DE
            Epix3D
            This is an upgraded version of the dynamic H(Housewife) Window.
            This window includes the complicated hinge which I am trying to work with the animation.
            The window is in right position when closed + horizontal. Problem is to position the different parts of multiple hinge joints to match the open window + make it work with the animation.
            Anyone dare the challenge?
            H Window with hinge
            • DareDevilD
              DareDevil
              DC challenge ? I'm here !! ๐Ÿ˜† ๐Ÿ˜†
              If I have some time to spend on it, I will try next days...
              Did you have more info about this kind of window ? I think there is a rail to connect the top end of the window to the fixed frame, but not in your model...
              • Epix3DE
                Epix3D
                Yes, -you are right Didier, I just did not model it ๐Ÿ˜ณ
                Attached is an updated version with the track hinge
                The window should be correctly placed in the horizontal position now, -but out of place in the two other positions.
                See photo
                If you look close you can imagine the L-fitting and track marked on this photo.
                H-Window
                Updated version
