    Groove lines, horizontal and vertical
    6 Posts 3 Posters 768 Views 3 Watching
    • B
      bravoddb
      Hi, are there any plugin to make groove lines, horizontal and vertical at the same time?
      I need to make a grid on a face, (separated by a joint with 5mm depth)then drop different materials on every rectangle.
      Bravoddb
      • jolranJ
        jolran
        Hi!
        Maybe not groove lines, but my plugin can give you a cross grid of edges with custom spacing fitted to face. Maybe 2 of thoose and explode onto face?
        http://sketchucation.com/forums/viewtopic.php?t=38637
          See all this thread for ideas! πŸ˜‰
            And this one
            πŸ˜‰
            If you have the Pro version Seems Boolean Diff function can make directly that you want
            Just make one solid of the volumes to remove
              Else a little method with free version πŸ˜„
              Clean Up by thomThom
              AddFaces by TIG
              Can work of course for any lines, curves...
              πŸ’š
              http://www.moulins-alma.fr/173-362-thickbox/gaufrier-coeur-electronique-inox.jpg
              • B
                bravoddb
                Pilou, you are awesome!!!!
