    Scene Naming BUG !!!
    5 Posts 4 Posters 774 Views 4 Watching
    • dereiD Offline
      derei
      %(#BF0000)[A very nasty BUG that occurs when working with Scene NAMES.
      It appears when renaming a scene.]
      HOW TO REPRODUCE:
      -set two scenes with different names.
      -Rename one scene but NOT press enter.
      -Click on the other scene.
      RESULT:
      The clicked scene will get the name instead of intended scene.
      POSSIBLE FIX (addressed to Trimble):
      Update the scene name on blur for Name field, not on another click/enter action.
      DESIGNER AND ARTIST DEREI.UK
        Jim
        I see it too. Not a show-stopper, but it doesn't seem right.
        • dereiD Offline
          derei
          Not a show-stopper, but I screwed-up a 40+ scenes project trying to quickly rename some scenes... I was in a hurry and when I noticed what I've done, I ended up with about 10 scenes having the same name...
          Also, is enough to just click in the name field, even if you don't change a thing (let's say you changed your mind and you don't want to rename)... if you click on the next scene, you will end up with two scenes having same name. This is how it happened to me.
            ArCAD-UK
            Known about this for ages so I'm careful with my renaming. +1 it's a bug that needs fixed.
              jpalm32
              "Known about this for ages"?? .
              Makes you wonder what they have been doing.
              There must be a hundreds od little crappy simple fixes they never bother to fix.
              And yes I say simple.
              You're not talking hundreds of hours SW time for some of thes things.
              Steve Jobs was correct. Google is (was) a lazy company.
