    Face to Framing Plugin?
    42 Posts 15 Posters 6.6k Views 15 Watching
    • KrisidiousK
      Krisidious
      Am I correct in my assumption that there is currently no plugin that will transform faces into frame walls?
      I have house builder that draws frame walls and allows windows and doors to be added and I have 1001 bit tools pro with a similar draw a wall and add a window or door. But nothing to transform faces into framed walls...
      so you know of anything I don't?
      By: Kristoff Rand
      • mitcorbM
        mitcorb
        Windowizer by Rick Wilson? Maybe?
        • cottyC
          cotty
          I know that I saw a video about a plugin that does this, but I don't remember the name... so there is one out there.
          my SketchUp gallery
          • mitcorbM
            mitcorb
            That wouldn't be Housebuilder, originally by Steve Hurlbutt?
            • KrisidiousK
              Krisidious
              No I have housebuilder and it does not do it.... neither does windowizer.
              By: Kristoff Rand
              • S
                sonder
                Well when it gets developed I want it!
                • KrisidiousK
                  Krisidious
                  I emailed Goh and asked him to add it... I tried using his hip roof face to framing and it almost works. I think it should be fairly easy to create. However I know nothing about ruby soooo...
                  By: Kristoff Rand
                  • soloS
                    solo
                    I'm pretty sure it does exist, I believe I had it with SU 5, I cannot remeber what the heck it was called.
                    http://www.solos-art.com
                    • soloS
                      solo
                      Was it this?
                      • KrisidiousK
                        Krisidious
                        That's house builder... It draws walls but doesn't build them from faces with windows and doors. it is pretty kool, I'm just extra lazy and it doesn't build proper corners.
                        By: Kristoff Rand
                        • pbacotP
                          I was querulous recently about something similar, a way to array battens on a face, though this is would be more complex. Would you use the framing in construction drawings. I'd be interested too.
                          I've done some framing models for more complex or unique structures, but the stud work was just for completing the picture. That is, in my CD's showing actual standard stud layout is never an issue, whereas the builder might want to do it for himself. I know of contractors who model all their own framing before building.
                          • R
                            raineysky
                            +1
                            • KrisidiousK
                              Krisidious
                              I can't believe it's not already in 1001 bit tools pro.
                              some of his scripts already do the same thing just a little short of this though.
                              404 Not Found
                              (www.1001bit.com)
                              By: Kristoff Rand
                              • mitcorbM
                                mitcorb
                                Maybe Chuck "Instant" Vali can develop it? Seems maybe like instant wall. 😒
                                  see this post 😉
                                  And generate Ceiling grid by Sdmitch ?
                                  • KrisidiousK
                                    Krisidious
                                    Yes I've used that tool for some things... But it won't frame out the house. it would be easier just to edit his draw wall tool results.
                                    By: Kristoff Rand
                                    • R
                                      raineysky
                                      Any word on this Kris? Housebuilder is so close. With Hip roofs it would be even better. I think someone added some code not long ago that centers the doors properly too.
                                      • KrisidiousK
                                        Krisidious
                                        Nothing yet.
                                        By: Kristoff Rand
                                        • KrisidiousK
                                          Krisidious
                                          Exciting things are happening... more to come. stay tuned.
                                          By: Kristoff Rand
                                          • KrisidiousK
                                            Krisidious
                                            Are you excited? Because you should be... I have in my possession what your hearts desire.
                                            By: Kristoff Rand
                                            • 1 / 3
