πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Face to Framing Plugin?
42 Posts 15 Posters 3.5k Views 15 Watching
    Krisidious
    Am I correct in my assumption that there is currently no plugin that will transform faces into frame walls?
    I have house builder that draws frame walls and allows windows and doors to be added and I have 1001 bit tools pro with a similar draw a wall and add a window or door. But nothing to transform faces into framed walls...
    so you know of anything I don't?
    By: Kristoff Rand
      mitcorb
      Windowizer by Rick Wilson? Maybe?
        cotty
        I know that I saw a video about a plugin that does this, but I don't remember the name... so there is one out there.
        my SketchUp gallery
          mitcorb
          That wouldn't be Housebuilder, originally by Steve Hurlbutt?
            Krisidious
            No I have housebuilder and it does not do it.... neither does windowizer.
            By: Kristoff Rand
              sonder
              Well when it gets developed I want it!
                Krisidious
                I emailed Goh and asked him to add it... I tried using his hip roof face to framing and it almost works. I think it should be fairly easy to create. However I know nothing about ruby soooo...
                By: Kristoff Rand
                  I'm pretty sure it does exist, I believe I had it with SU 5, I cannot remeber what the heck it was called.
                    Was it this?
                      Krisidious
                      That's house builder... It draws walls but doesn't build them from faces with windows and doors. it is pretty kool, I'm just extra lazy and it doesn't build proper corners.
                      By: Kristoff Rand
                        I was querulous recently about something similar, a way to array battens on a face, though this is would be more complex. Would you use the framing in construction drawings. I'd be interested too.
                        I've done some framing models for more complex or unique structures, but the stud work was just for completing the picture. That is, in my CD's showing actual standard stud layout is never an issue, whereas the builder might want to do it for himself. I know of contractors who model all their own framing before building.
                          raineysky
                          πŸ‘
                          +1
                            Krisidious
                            I can't believe it's not already in 1001 bit tools pro.
                            some of his scripts already do the same thing just a little short of this though.
                            1001bit.com - Architectural Tools for Sketchup
                            (www.1001bit.com)
                            By: Kristoff Rand
                              mitcorb
                              Maybe Chuck "Instant" Vali can develop it? Seems maybe like instant wall. πŸ˜’
                                see this post πŸ˜‰
                                And generate Ceiling grid by Sdmitch ?
                                  Krisidious
                                  Yes I've used that tool for some things... But it won't frame out the house. it would be easier just to edit his draw wall tool results.
                                  By: Kristoff Rand
                                    raineysky
                                    Any word on this Kris? Housebuilder is so close. With Hip roofs it would be even better. I think someone added some code not long ago that centers the doors properly too.
                                      Krisidious
                                      Nothing yet.
                                      By: Kristoff Rand
                                        Krisidious
                                        Exciting things are happening... more to come. stay tuned.
                                        By: Kristoff Rand
                                          Krisidious
                                          Are you excited? Because you should be... I have in my possession what your hearts desire.
                                          By: Kristoff Rand
                                          • 1 / 3
                                          1 / 3
