    ScaleTool AND TextBox
    5 Posts 3 Posters 1.0k Views 3 Watching
    • ninomaydaN
      ninomayda
      Need "direction" from the "Experts" here. Would like end user to be able to adjust width of an object using either one; "ScaleTool" and/or "TextBox" entry. Have played with the Current() Attribute function with little success. I can figure a way out of Circ Refs.
      Regards.
      Nino
      • J
        Jim
        Did you find your answer? If no, it's just a few posts down on this very forum 😉
        http://sketchucation.com/forums/viewtopic.php?f=289&t=50742
        • DareDevilD
          DareDevil
          There is no problem to enter the value in a text box in the Component option windows AND let the user manualy scale it.
          If you have a problem to do that, send us the file to understand the problem.
          DC-scale_and_textbox.skp
          • ninomaydaN
            ninomayda
            [attachment=0:1xspv43i]<!-- ia0 -->DC-scale_and_textbox.skp<!-- ia0 -->[/attachment:1xspv43i]
            Thanks for your solution. Exquisite. We look "outside" of the box while the real answer lies in specifying LenX.
            Brilliant, straight forward and so simple.
            Thanks again. 😍
            Nino
            • J
              Jim
              Is it that simple? It is more complicated when you want to put constraints on the value such as snapping to whole numbers, or making minimum length.
