    Debris creation and convex hull creation
    3 Posts 2 Posters 471 Views 2 Watching
      DasMatze
      Some quick questions:
      • Are there any plugins that are able to slice a solid into debris (different types of debris like wooden planks, bricks, stones, tiles, ...) and groups each object?
      • Is there a plugin that turns a concave solid into convex grouped solids?
      • If not is there at least a plugin that allows you to slice and group the selected solid simply by drawing a line?
      It would really speed up model creation for engines like the Source engine.
      A short answer/link is completely enough. Thank you in advance!
        Maybe SUSolid can help you ?
        See also Make Fur by Tak2hata (maybe not fracturation but visual result will be the same)
        http://sketchucation.com/forums/download/file.php?id=47832
        and the tricky Replace Random Component by Sdmitch
        Zorro2 draw a line and cut the volume but don't close the volumes! ๐Ÿ˜ฎ by Whaat
        Addfaces by Tig close the volumes but volumes must be isolated (disconnected) ๐Ÿค“ by Tig
        Eclate deplace explode solids from each other but solids must be yet groups or components! ๐Ÿค“ By CPlassais and me
        fracture Voronoรฏ XY is in developpment! by MattC
        Loose geometry to groups group isolated selection volumes in groups By Chris Fullmer
        Groups to components By Thomthom
        Faces to components make each face a component By TIG โ˜€
        Thickness to Component give a thickness to a selection "flat" components by Sdmitch ๐Ÿ˜Ž
        So Zorro2 + Faces to component + Eclate deplace + Thickness to Component can be a cool solution ๐Ÿ˜‰
        see my post here ๐Ÿ˜‰
        links are inside; have fun fracturation! Not hydraulic! ๐Ÿ˜‰
        http://sketchucation.com/forums/download/file.php?id=101601
        http://sketchucation.com/forums/download/file.php?id=100446
        Random Painter
        by Chris Fullmer ๐Ÿ˜„
          DasMatze
          Thank you very much, Pilou!
          Apart from Zorro I think I'll be better off doing these tasks as I'm used to but those plugins are helpful nonetheless.
