    [Code] save Camera properties method
    4 Posts 3 Posters 503 Views 3 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      [ Code ] save camera properties method
        #{ save_camera_properties( camera )
        #  Save properties of a Sketchup;;Camera object.
        #  Arg; camera (an optional Sketchup;;Camera object.)
        #       With no argument, defaults to using the;
        #       Sketchup.active_model.active_view.camera()
        #  Returns a Hash of all the camera properties.
        def save_camera_properties(cam=nil)
          unless cam.is_a?(Sketchup;;Camera)
            cam = Sketchup.active_model.active_view.camera
            puts("Using current view's camera.") if $VERBOSE
          verbose = $VERBOSE
          $VERBOSE = nil # suppress cam.height warning.
          h = Hash[
            ;aspect_ratio, cam.aspect_ratio,
            ;description,  cam.description,
            ;direction,    cam.direction.to_a,
            ;eye,          cam.eye.to_a,
            ;focal_length, cam.focal_length,
            ;fov,          cam.fov,
            ;height,       cam.height,
            ;image_width,  cam.image_width,
            ;perspective,  cam.perspective?,
            ;target,       cam.target.to_a,
            ;up,           cam.up.to_a,
            ;xaxis,        cam.xaxis.to_a,
            ;yaxis,        cam.yaxis.to_a,
            ;zaxis,        cam.zaxis.to_a
          $VERBOSE = verbose
          return h
        end #}
      πŸ’­
      I'm not here much anymore.
        tomasz
        Each camera has also following properties not available from Ruby:
        bool FieldOfViewIsHeight - whether FieldOfView is measured in the y direction
        bool Camera2D - whether a camera is 2D or not
        Center2D - 2D Point - center of a camera in 2p perspective mode
        Scale2D - double - scale (zoom-in/out) for 2p perspective view
        • greenskpG Offline
          greenskp
          Hi Dan Rathbun
          all this code is to work in MAC and PC?
            Dan Rathbun
            Yes it will work on both Mac and PC.
            BUT it is meant for you to copy it INSIDE your plugin sub-module.
