    [Code] save Camera properties method
    4 Posts 3 Posters 527 Views 3 Watching
    • Dan RathbunD
      Dan Rathbun
      [ Code ] save camera properties method
        #{ save_camera_properties( camera )
        #  Save properties of a Sketchup;;Camera object.
        #  Arg; camera (an optional Sketchup;;Camera object.)
        #       With no argument, defaults to using the;
        #       Sketchup.active_model.active_view.camera()
        #  Returns a Hash of all the camera properties.
        def save_camera_properties(cam=nil)
          unless cam.is_a?(Sketchup;;Camera)
            cam = Sketchup.active_model.active_view.camera
            puts("Using current view's camera.") if $VERBOSE
          verbose = $VERBOSE
          $VERBOSE = nil # suppress cam.height warning.
          h = Hash[
            ;aspect_ratio, cam.aspect_ratio,
            ;description,  cam.description,
            ;direction,    cam.direction.to_a,
            ;eye,          cam.eye.to_a,
            ;focal_length, cam.focal_length,
            ;fov,          cam.fov,
            ;height,       cam.height,
            ;image_width,  cam.image_width,
            ;perspective,  cam.perspective?,
            ;target,       cam.target.to_a,
            ;up,           cam.up.to_a,
            ;xaxis,        cam.xaxis.to_a,
            ;yaxis,        cam.yaxis.to_a,
            ;zaxis,        cam.zaxis.to_a
          $VERBOSE = verbose
          return h
        end #}
      I'm not here much anymore.
      • T
        tomasz
        Each camera has also following properties not available from Ruby:
        bool FieldOfViewIsHeight - whether FieldOfView is measured in the y direction
        bool Camera2D - whether a camera is 2D or not
        Center2D - 2D Point - center of a camera in 2p perspective mode
        Scale2D - double - scale (zoom-in/out) for 2p perspective view
        • greenskpG
          greenskp
          Hi Dan Rathbun
          all this code is to work in MAC and PC?
          • Dan RathbunD
            Dan Rathbun
            Yes it will work on both Mac and PC.
            BUT it is meant for you to copy it INSIDE your plugin sub-module.
