    Bmike, timber frame & CNCMike,
    1 Posts 1 Posters 321 Views 1 Watching
    • K Offline
      KrisM
      Mike,
      Your timber frame work is exceptional. I presume that although the timber frame rubies are set up to produce drawings for hand cutting, that you must produce designs for firms which use CNC for doing their cutting. The software with which I am familiar (Cadwork) really needs a sat file for import. Since SU's solids are not really solids and there seems to not be a easy method to convert the objects to true solid objects, do you have a clever method to deal with this?
      KrisM
