    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Error message while rendering in su podium
    2 Posts 2 Posters 1.3k Views 2 Watching
      anandlele
      kindly guide for following error message when rendering in SUPodium
      the model is loaded
      put it to render in SUPodium
      the reading file stops at 80% and the following message appears on screen
      microsoft visual c++ runtime library
      run time error !
      program :c:\program files(x86)\google.....
      this application has requested the runtime to terminate it in an unsual way.
      please contact the application's support team for more information
      when this window is closed following message appears
      oopr.exe has stopped working
      a problem caused the programme to stop working correctly
      windows will close the programme and will notify you if a solution is available
      kindly guide as soon as possible
      anand
      • bunnyackB Offline
        bunnyack
        according to this link, this problem is usually caused by outdated versions of the Visual C Runtime libraries. The link refers to a similar problem with IE 8, so it has nothing to do with SU Podium. However, the link might be interestingm to you, as long as you havn't read it already. (Its the first one that pops up when you google the error message ๐Ÿ˜‰
