    Help creating a 2d model of a 3d model
    4 Posts 4 Posters 813 Views 4 Watching
      DohkoGsr
      Hello, i'm from mexico, and i have some issues trying to make a 2d face of one 3d model this is the 3d model
      http://i873.photobucket.com/albums/ab298/dohkogsr/show_zps31edabad.png
      i need to print and make my model in real, sorry for my english 😄 i don't know if i explain my point
      • mitcorbM Offline
        mitcorb
        You could use the Sketchup Sandbox Tool called Drape. The methods are viewable on YouTube for instance.
        • cottyC Offline
          cotty
          Do you need a 2D projection (you can use parallel top view for printing) or a flattened version of the face?
          my SketchUp gallery
          • dukejazzD Offline
            dukejazz
            To process a faces to a 2d or to a 3d model
            1. Copy and then flatten one 3d model to a 2d model with scale tool
            2. draw rectangle on back plain, useing the move tool, move the left corner, by left click and hold buttom of mouse while dragging the rectangle to front plain, above the flatten 3d high spot. Then turn on xray and make a face to 2d model.
            3. Now return face to 3d model with push-pull and paste in place 3d model or vector push-pull witch tranfer flatten 3d detail to 2d model.
            4. Right click and used context intersect face to model
            5. Cut off ends of the pull face or the 2d rectangle edges.
              delete 3d flatten model
            Answer
            You now made a 2d face or a 3d face suface via 1-6
            Now for terrain lines,
            Answer:
            1. draw rectangle on ground plain, use move tool to front left corner, left click hold buttom of mouse while pressing the control key. Now drag the
              rectangle to top plain. type in the indext input box type /20 enter
            2. right click and used context intersect face to model
            3. Cut the 2d rectangle plains edges.
