    RandomBetween Not very Random
    7 Posts 3 Posters 1.1k Views 3 Watching
    • ninomaydaN Offline
      ninomayda
      I've set up two separeate variables to generate "RandBetween(1,5)" and "OnClick" to "Redraw". When Redraw occurs, I invariably get the exact same result on BOTH RandBetween variables. I would have expected 2 different random values.
      Nino
        Jim
        Hi Nino,
        I see the same behavior. Seems like a bug in DC's.
        As an alternative, you can use something like:
        =round(rand() * 4 + 1)
        • DareDevilD Offline
          DareDevil
          Same with RAND()...
          If the formula is the same, the result is the same.
          But, if you add a number between the bracket, the random number will be different for each different number.
          = CEILING ( RAND(1) * 5)    (same as = ROUND ( RAND(1) * 5 + 1)
          generate different result than
          = CEILING ( RAND(2) * 5)
          Be carrefull, this is not the same as RANDBETWEEN(1,5), giving a number in [1, 2, 3, 4,5].
          ROUND(RAND() * 4 + 1) give a number in [1, 2, 3, 4].
          RAND() give a number 0 =< X < 1
          RAND() * 4 give a number 0 =< X < 4
          RAND() * 4 + 1 give a number 1 =< X < 5
            Jim
            Here's what I did. 3 identical formulas, 3 different values between 1 and 5.
              DareDevil
              @daredevil said:
              Same with RAND()...
              I was intresded with your video : all the opposite to my experience !!
              So... I tested and tested again, and finally I understand why !!! 😄
              If you type in uppercase (RAND() or RANDBETWEEN(1,5)) or use the help to insert function (that write it in uppercase), same formulas produce same result.
              But if you write in lowercase (rand() or randbetween(1,5)) each folmula produce a different result, the random is "realy" random !
              If you use mixed case, Rand() produce same result as other Rand(), but different to RaNd() that produce same as other RaNd()...
              I used to type in uppercase in DC, but now, I will always use lowercase, like in Ruby 😆
              Thanks Jim for you exemple 👍
                Jim
                Hi Didier,
                Thank you for investigating further.
                I am very surprised that the difference of behavior is based on the case of the letters! Not cool.
                  ninomayda
                  @daredevil said:
                  @daredevil said:
                  Same with RAND()...
                  If anybody was going to provide an answer . . . . it was shure to be SketchUcation. THANKS.
