    Formula needed!!!
    4 Posts 4 Posters 1.4k Views 4 Watching
    • K Offline
      kilwhan
      Hello everyone,
      I'm trying to find out if a formula is available in functions to compile the number of same components in the document, so that when I "generate report" it will tell me how many there are. The image attached pretty much explains what I want to do.
      If anyone cane it would be greatly appreciated.
      Thanks to all!
      • P Offline
        pcmoor
        One could place a total within the component name, description. refer to my rafter, or PFC model (pcmoor) do the take-off then hide (delete) the attributes not require or your presentation
        and/or build a simple VBA control within (or independent of) the spread sheet which would total up and reformat the page. .
        on another note, it would be good if the name attribute was tied to a label, similar to the blocks in AutoCAD. I created and currently use an estimating (VBA) program within AutoCAD for my work as an timber framing estimator, started playing around with sketchup, early days and time permitting.
          DaveM65
          This is the kind of thing I require, but to include, Buy in cost, Sell on cost and hire cost....
          Its an interesting question and problem
          Dave
          • G Offline
            goga63
            try using a plug-in Solid Quantify by TAK2ATA. author website http://sketchup-onigiri.jimdo.com/plugin-other/
