    How to get the bounding box of a CAD car?
    7 Posts 4 Posters 1.1k Views 4 Watching
    • lbsswuL Offline
      lbsswu
      I have some CAD cars and I need to project these 3D models to 2D images, is there a method to get the 2D bounding box coordinate of a car in each image? e.g., the 4 corner coordinates, (x1,y1), (x2,y2), (x3,y3), (x4,y4) of the green bounding box in the following attachment.
      • Dan RathbunD Offline
        Dan Rathbun
        You would insert each car component onto a new layer, switch to that layer, and turn all other layers OFF, and zoom extents.
        Then use view.write_image to create the image files.
        I'm not here much anymore.
        • lbsswuL Offline
          lbsswu
          Suppose there is one car in a image, how to get the coordinates of the car's bounding rectangle?
            You don't need to find those [even if you could] because the Zoom Extents on a single car does that in the view.
            Of course depending on your screen's current proportions and the exact view of the car you will get some 'white space' around the image.
            If you don't want all images to be the same size then that 'white space' is best removed with an Image editor [like Gimp] - where you can batch-open each file in turn and Auto-Crop it and save, to ensure that each car occupies as much of the image as possible...
            • dukejazzD Offline
              dukejazz
              It is true you may not need bounding box corner coordinate of a car in each image to make 3D models to 2D images,
              by lbsswu » February 28th, 2013, 11:58 pm
              Yes You can turn 3D models to 2D images,
              method 1) flatten it with scaleGroupFloat_dj Ver 1.6.5
              Copyright Feb 15, 2013
              DukeJazz: by James Cochran
              when color leaves then it flat
              recolor with in model texture
              I use four boxpoints to four corner (boxPoint_dj)
              then readed the c-point to target
              method 2) a clip trxture - edit to transpaency background-input image
              There is 2 methods beside mine above to get the 2D bounding box coordinate of a car.(x1,y1), (x2,y2), (x3,y3), (x4,y4)
              method 1) Ruby ATI method is given here for bounding box coordinate
              http://www.sketchup.com/intl/en/developer/docs/ourdoc/boundingbox#corner
              method 2) If you have the SU Pro save a export to VRML and open to notepad, lookie here coordinates
              • lbsswuL Offline
                lbsswu
                thanks for your kindly reply, I will try these method.
                • lbsswuL Offline
                  lbsswu
                  thanks for your tip! maybe I will do that in the future.
