    [Plugin] Projection Builder
    4 Posts 3 Posters 10.1k Views 3 Watching
    • monkeybanjoM
      monkeybanjo
      Description
      Builds a top, front and side projection from a model and arranges them onto a single plane for easy dimensioning and printing. The current version of the plugin only builds the projection from edges, not on groups/components. This means that groups need to be exploded before a projection can be built. Typically, I use my "Recursive Explode" plugin which I also uploaded to explode all groups and subgroups before creating a projection.
      Installation
      The zip file attatched should be unzipped into the plugins directory
      How to Use
      Simply select something, and then choose the Tools > Build Projection menu option.
      Cheers,
      Dave
      ProjectionBuilder.zip
      • gillesG
        gilles
        Is this different or better than TIG's Flatten to plane?
        http://sketchucation.com/forums/viewtopic.php?f=323&t=31895#p281320
        • monkeybanjoM
          monkeybanjo
          Not sure, I'll check it out, thanks πŸ˜„
          • A
            Archtiex
            Thanks.. but are you trying to get closer to RHINO MAKE 2D command??
            If you work a litle bit more, you gone win on this. I which you could add choose layers when projection are done, because it is very dificult to diference VIEW LINES from a CUT Line. And try to get better performance, because i try it on a small example and it took like 1 minuto do complete. (and i have a great machine workstation and SU 2015 x64bits)
