    DC Where are the Decimals
    4 Posts 2 Posters 941 Views 2 Watching
    • ninomaydaN Offline
      ninomayda
      LenZ = 22; Copies = 5. When an element's height = LenZ/Copies I get = 4. Right answer = 4.4. I inded get 4.4 with LenZ/5. What gives?
      • DareDevilD Offline
        DareDevil
        Can you send the file with the problem ? I tried to do the same and I always get 4.4
          ninomayda
          This is uncanny not to mention embarrassing. I invested 4+ hours yesterday on this DC and could not get decimals produced from the calculations. I shut down SKP and re-started more than twice in order to flush buffers (Re-Do’s) and the integers without decimal calcs kept coming through. When I fired the PC to provide you the requested actual model for this thread, it all works out honky dory. I swear the problem was there yesterday. Can’t explain how it was fixed or if it’s going return in future instances for this DC.
          The Field that would not return decimals is = “RiserActualHeight”
          SAF StairsOneRun.skp
            DareDevil
            It's OK 😉
            A friend of mine says "computers ? it's easy : just work with 0 and 1... but sometime there are many mysterious thinks between them..." 😉
